Project: CPU STINGRAY
MonsterMawd
Level 12
The now hard to find, CF-1009 Midtower by AMS Electronics. remains my all time favorite. Its the most durable construction for an aluminum case I've seen to date. You can easily remove the 2 piece acrylic bezel and plate for cutting fan holes. LED and PWR/RESET buttons are screwed in versus glued. The HD cage is removable. You can modify it so you have, Front and Rear 120 fans. It's painted aluminum, not anodized so less prep work painting. I would still chose this case over any Lian Li. It's simplistic plain jane design makes a great canvas for mods. Tom's Hardware review of midtower version, CF1006
Sadly though, I'd be surprised if you could find this case anymore...
16 REPLIES 16
xeromist
So you were saving the last one in captivity for a rainy day? 🙂
It is a Rainy Day 🙂
Custom (4" rise) cowl induction hood on 1999 Corvette
1972 Corvette Stingray
"Vette-style" hood w/ high rise cowl induction. This will be covered with fiberglass filler. It will cover the lower portion of the front bezel. It will attach w/ it's nose downward, via 4 hood pins... so its easily removable. The cowl portion will have a intake grill made from Modders Mesh.
22 gauge galvanized steel.
Filled crevices with 3M ScotchWeld DP-190. Let it cure for 24 hours.
1/16th sheet of styrene plastic. Holding over heatgun to form over intake bezel frame
Using DP-190 again to attach hood cowl onto styrene
Evercoat's EVERGLASS Fiberglass filler
Within 15 -30 mins, Everglass is ready for sanding. Here I'm using a Black & Decker Mouse sander with corse grit paper
After sanding the first coat, I laid the hood against the bezel and noticed the styrene had warped on the right side. I resanded it, then placed 3, 1 gallon paint cans on the hood as the filler cured for 24 hours. Yes, the cans were FULL :shock: Evercoat's EVERGLASS has awesome strength!
I'm going to touch up these spots in another hour
xeromist
LOL@paint cans
Powdercoated Chassis. Candy Apple Red powdercoat
trim for the 5.25 bay I cut from a pre-made rigid sheet of CF.
Bulgin Vandal Resistant Illuminated Switch - Red Ring MPI002R performance-pcs
Added 1.5" washer and drilled a 3/4" hole in center to fit over the switch and make it appear larger. I then covered the switch and washer w/ masking tape, then cut along the outside edge of the light ring w/ exacto knife. So now you have inner push button portion covered with tape... I then sanded the exposed alum w/ 400 grit sandpaper. Then applied Metalcast Red, then after 24hrs, a laquer clearcoat. The clearcoat is crucial, cause Metalcast chips very easily
I'll be mounting the Black Ice Extreme III in the top panel, so the dual 80mm exhaust should really help pull out warm air above the PSU. I really wanted to jazz up the dual 80mm exhaust. I've seen people mount tail pipes on cases.. Since thats already been done, I designed this billet aluminum accent plate. The 80mm AOC fans have milled aluminum frames with plastic chrome blades. I hate the white colored hubs and know others feel the same, so I covered them with carbon fiber vinyl film ...plays off the bezel trim as well.
The fan holes were finished with u-channel molding and fan mounting grommets that help elminate fan vibration.
I used Honeycomb Modders Mesh for the grill behind the aluminum accent plate
PC Power & Cooling Turbo Cool 850 Ultra SSI, 950W peak power. Measures 5.9" x 3.4" x 9.0"
Sleeved with these new PSU Tools
http://www.mnpctech.com/ATX_Molex_Removal_Tools.html
"Will it fit Captain?!"
Pmadison
Looking brilliant!
Thank you!
I love Kandy Apple Red, esp on a Street Rod....
We had painted a Corsair 800D the same color last year for HWC
MonsterMawd
Level 12
Using 5.5" mikuni carb filter covers, mock them up to look like 427 chrome filter covers... Looks like dual V8s lying beneath our bezel. GM' cross-fire-injection V8s
I went over the 4-3/4" diameter... oh well, even better airflow in my book
I'm morphing the Corvette 427 decal/AMD FX logo into a new filter decal
Anodized Red pop rivets I scored from friend who used to sell the, unfortunately he doesn't anymore....
I may have replace the #8 size butterfly nuts with #6s to clear the hood. I'm allowing the hood paint to cure for couple days before I handle it.
Its just like setting the idle adjustment on carbs, set them, shut the hood and Go! 😄
The hood will be held on with R/C body mount kit from anodized red hood pins
Drilling mounting holes for hood pin mounts
5.25 Bay res from DangerDen
Hood is buffed... and ready for action...
Download AVI @ 440K
Jewerly box support hinge from Rockler
Modified... of course
Da big case badge!
Corvette C5 emblem. I modified the emblem a tad and raised it with 1" backing made from wood, then covered with spot putty, painted, then carbon fiber vinyl.
More "in your face" look I wanted.
The ring never turned my crank much <_<
1" thick pine (backing)
Spot putty, then paint
