Glad to hear you got it working... should have thought about that conflict. I'll make note of it and adjust the guide for existing build 203 laptops. Has anyone checked the added options in the bios and made any adjustments?
OS: Windows 7 Home Premium 64-bit Service Pack 1
System Model: G74Sx-A2
Processor: Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz (8 CPUs), ~2.0GHz
Memory: 16384MB RAM
Drive C:
Total Space: 127.0 GB
Model: INTEL SSDSA2CW160G3
Drive D:
Total Space: 715.4 GB
Drive E:
Model: Slimtype BD
Card name: NVIDIA GeForce GTX 560M
Display Memory: 2767 MB
Dedicated Memory: 3034 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Audio Description: Realtek Digital Output (Realtek High Definition Audio)
@Swifty: Is there a reason you specifically suggest people use WinFlash when trying your BIOS hack? One of the most common and vociferous recommendations around Asus forums is to avoid WinFlash, since it's known to be the most risky flashing method.
You may want to include that in your disclaimer of liability, i.e., that using the WinFlash utility, as suggested in your instructions, increases the probability of bricking the BIOS. (It might also be a good idea to make it very clear that flashing a modded BIOS instantly voids the Asus warranty, so in the even that the BIOS does get bricked, the RMA will have to be done at the owner's expense. This has been stated elsewhere, but those considering your hack may not see it unless you include it in your posts.)
I have never had a problem with winflash, I will make note of that and add an alternative method. Just for those who are sceptical of the winflash method.
Memory: 16384MB RAM
Drive C:
Drive D:
Drive E:
Model: Slimtype BD
I am seriously debating doing this now....Throttle Stop has stoped functioning in monitoring mode properly for me. I now have to "Turn ON" Throttle Stop and put the "Set Multiplier" to 28 to get full speed while gaming.
I am not sure why TS stopped functioning in monitoring mode for me... i have made no updates or changes to any drivers at all.
....hummm....now i have to weigh the pros and cons on lack of warranty.....
Rozwel911
G74SX-DH73-3D
rozwell your pm replied.
Click ->Republic of Gamers<- official Facebook page
Ok just one question that the R&D teams wants me to ask you guys.
Regarding the throttling of CPU, what software did you guys track the "mhz" ? CPUZ?
*knock knock*
Hi guys,
Could you all try this out to see if the CPU frequency drops to below 800mhz? like gaming etc etc
http://downloadcenter.intel.com/Deta...x?DwnldID=7838
Something like this
So do we have to run Furmark while running this app? Also is there some reason that we have to use this app instead of CPU-Z?
SWTOR test below with all max settings minus shadows which are set to low. Not that it won't do it, just prefer it.
Doesn't seem like the Intel app monitors the processor, just takes a one time snap shot when it launches. Which by the way, according to CPU-Z, caps the freq before dropping down.
G74sx-NH71
Intel Core i7 2670QM, 2.2Ghz
12GB Ram
500GB HDD @ 7200 rpm
Nvidia GTX 560m 3gb (285.79 driver)
