Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Guru: Green Belt Array Henkenator68NL PC Specs
    MotherboardRampage V Extreme
    ProcessorIntel Core i7 5960X
    Memory (part number)G.Skill Ripjaws V
    Graphics Card #1R9-290X
    Graphics Card #2R9-290X Matrix Platinum
    Graphics Card #3HD 6970
    Graphics Card #4HD 5970
    MonitorAcer Predator XB720H 144herz 1ms
    Storage #1Samsung EVO 850 1TB
    Storage #2Seagate 2TB
    CPU CoolerCustom Watercooled loop
    CaseCooler Master HAFX and Storm Stryker
    Power SupplySeasonic Gold 1250W
    Keyboard Logitech G19
    Mouse RAT 7
    Headset Logitech G35
    Mouse Pad Steel series
    Headset/Speakers Logitech X 5.1 Surround
    OS Windows 10 Pro 64bit
    Henkenator68NL's Avatar
    Nov 2011
    Location
    Franeker, Netherlands
    118
    741
    Water Cooling RAM Usefull? You Bet! Here are my Test Results
    Hello ROG Community,
    I have been Tweaking my System for as long as i can Remember. Water Cooling is one of my favorite ways to keep it Cool! Most Water Cooled Systems comprise CPU, GPU and motherboard. But RAM Coolers I did not see a lot of it.
    But since I was curious to know if there was any point to Water Cooling your RAM, I put it to the Test.
    I got myself 4 RAM Coolers from: Alphacool, the Alphacool NexXxos RXP-1 Ram Coolers. I picked those Coolers because you can individually cool each Ram Stick.
    So I ran a series of tests with my system while the RAM was still passivly cooled and after mounting the RAM Coolers I ran the same Tests. The first trick was hoe to measure the temperature of the RAM Sticks: so I carefully placed a Thermal Sensor between RAM stick 2 and 3.
    I Ran HWINFO64 and logged temperatures of:
    - The Cores
    - The CPU
    - The Motherboard
    - The North- and SouthBridge
    - The Temp of the 2 Cores from my GPU (6990 dual core with 4 Gb DDR5)
    I logged all Temps because I wanted to see if there was any influence on the other Temperatures by adding the RAM Stick to the Water Loop.
    Before Water Cooling the RAM I Currently Cooled on Water: The CPU and the GPU.
    This is the Ram Cooler:
Name:	Pic 04 Unboxing 06.jpg
ID:	12206Click image for larger version.
Name:	Pic 20 How to Link  Modules 02.jpg
ID:	12207Click image for larger version.
Name:	Pic 25 PC_Henkenator68NL 03.jpg
Name:	Pic 26 PC_Henkenator68NL 02.jpg
ID:	12209Click image for larger version.
Name:	Pic 27 PC_Henkenator68NL 01.jpg
ID:	12210Click image for larger version.
Name:	Pic 28 PC_Henkenator68NL 04.jpg
    It was kind of Tricky to get it to fit with 4 RAM Modules seated directly next to eachother, but I got it to fit (see Youtube video on How-to Install the Sticks).
Name:	Pic 22 Drawing Positioning RAM in RAM Cooler.jpg
    The Test Results where to my suprise very good!
Name:	Pic 30 Test Results Graphical Comparison Passive VS Water Cooled Memory v2.jpg
Name:	Pic 29 Test Results Spreadsheet Comparison Passive VS Water Cooled Memory v2.jpg
    The average Temperature of the RAM Sticks dropped from 53° to 37° Celsius !! A 30% Drop.
    The maximum Temperature (under Heavy Load) dropped from 87° to 49 ° Celsius, a 45% Drop!!
    There was hardly any negative result on the Temperatures of other key compenents.
    So Water Cooling your Memory does pay off!! The only down side was that the Flow Rate of the Cooling Liquid dropped quite a bit; but this did not seem to influance the Temperatures of the Components.
    Thought I share this with you all!
    Greetings Henk
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    Location
    Mount Pleasant, SC, USA
    163
    7,967
    Very interesting experiment, mate!
    I just missing the effect of that temp drop... I mean, it's clear that the memories are running at lower temps, but one would ask "so, what?!"... Is your system more stable? Can you OC higher?
    BTW, what do you mean by "heavy load" on the memory, what application? What were the memory settings?
    Mouse RAT 7
    Nov 2011
    Location
    118
    741
    I did indeed forget to mention the reasons why ...
    1. When you are overclocking your system, you want to keep temperatures down to: prevent damage, enhance stability
    2. All things count when achieving lowest possible temperature like:
    • The Air Flow in your Case
    • The Amount, quality and arrangement of the Fans
    • The Quality of your cooling equipment
    • The ambient temperature
    1. So when searching for improvement I noticed that the memory modules felt hot, they are radiating heath in the case (very close to the CPU). So I searched for ways to get the Temperature Down. This I achieved by Water Cooling the Memory.
    2. The final reason was overclocking capability of the RAM.
    3. I just finished testing and I managed to overclock the RAM to never before reached levels (by me). I now have the RAM running at 1800 MHz from 1333 MHz so that’s a huge improvement. Temperatures did not get over 54 ° [C] .
    I have added the picture of a stress test and all settings in CPU-Z, GPU-Z, HWINFO64 and AIDA64.
Name:	Water Cooled MemTest 1800Mhz 1hr Stress Test.jpg
    As for the question about the Heavy Load, I did several things to get the memory underload:
    - Stress Test AIDA64 for min. 3 hrs
    - Render a Movie (software mode)
    - Run PCMARK07
    - Play Battlefield 3 for at least 3 hrs online
    So what do you think?
    Greetings
    Henk
    Mar 2012
    Location
    163
    7,967
    I see... it's nice, no doubt!
    But, you didn't share anything regarding the airflow in your case... just persisting on this because I can push my memories very close to 3GHz just simply having a fan blowing on them (of course, that depends very much on the memories and IMC)... and I assume, their temps is not going over 40-45C - just assume, as didn't measure by a temp probe, just by touching them (and they felt just slightly warmer than my hands)...
    Not to be taken seriously Array Raja@ASUS's Avatar
    Apr 2011
    Location
    ASUS North America
    126
    5,625
    You need to drop temps down to freezing point to see a sizeable change in DRAM overclocking ability. Even then it comes down to the IC.
    You might be able to run tRFC a little tighter, as cell leakage can vary with temperature - lower temps generally leads to less leakage. The performance change would be negligible of course.
    ASUS Technical Marketing
    If you are located outside North America and require technical assistance or support, please contact ASUS Support for your region.
    For ASUS North America Service: http://www.service.asus.com/#!contact-us/cw8z
    Mar 2012
    Location
    163
    7,967
    Thanks, Raja, this really clears up things in my head...
    Now, considering the worse, when the airflow in the case is very bad and hot spots are forming - let's say - around the memory modules, causing them to run hot - would that reduce their performance/overclockability significantly? Also, let's just assume that the CPU's temps are OK by WC'ing...
  7. #7
    Mouse RAT 7
    Nov 2011
    Location
    118
    741
    Adding to Zka17's question:
    Does radiating heat from hot mem modules affect the temperature of the CPU. If so does that influence the CPU performance and or overclocking abbility??
    Does overclocking RAM boost any performance at all?? Does faster RAM bring you any performance boost?
    Hmmmm I think this needs more reseach, I am planning on buiding a Benchmark and Test System from scratch and I think I will look into this ....
    ps I am not as well educated into this matter at all, so I can only draw from self learned experiences !
  8. #8
    Mar 2012
    Location
    163
    7,967
    Self learned experiences are the best!
    If you can not cool off the CPU for whatever reason, then yes, it will affect the overall performance of the system... OC'ing the RAM will benefit mostly in benchmarks though, in everyday use the amount of it may be more important (but that also depends on the used applications)...
  9. #9
    ROG Guru: Yellow Belt Array danskieness PC Specs
    MotherboardAsus Maximus VI Impact
    Processori5-4670k
    Memory (part number)G. Skill Triedent X 2x4gb F3-2400C10D-8GTX
    Graphics Card #1MSI GTX 970 Gaming 4g
    Monitor2x Asus VX239h , 1x HP w2207h
    CPU CoolerCorsair H100
    CaseBitfenix Prodigy Red
    Power SupplyCorsair RM 650
    Keyboard Corsair k95
    Mouse Logitech G403
    Mouse Pad Steel Series QCK
    Headset/Speakers Edifier 3350
    OS Windows x64 8.1
    Jul 2012
    Location
    Philippines
    13
    223
    Quote Originally Posted by Henkenator68NL View Post
    hi there, i would like to share someone's post regarding that!
    CLICKY HERE
    Mobo : Asus Maximus VI Impact || CPU : i5-4670k || Cooling : H100
    GPU : MSI GTX 970 Gaming 4G || PSU : Corsair RM 650 || Rams : G Skill Trident X 4GBx2 2400 CL10
    Monitor : 2x Asus VX239h + 1x HP w2207h || Chassis : Bitfenix Prodigy Red || OS : WIN8.1 x64
    Periphirals : Corsair K95, Logitech g402, Edifier 3350
  10. #10
    Here is my ROG title Array Granger PC Specs
    Granger PC Specs
    MotherboardCrosshair Formula V
    ProcessorPhenom II 1100T
    Memory (part number)G-Skill RipjawsX 2x4Gb@1838Mhz
    Graphics Card #1Sapphire HD7970 OC VaporX
    MonitorSamsung Syncmaster 2253LW + 2 Packard Bell 19.5" vga
    Storage #1Samsung SSD 850EVO 250gb
    Storage #2250gb SSD + 4 HD 3Tb total + NAS 3Tb
    CPU CoolerSwiftech custom loop
    CaseCoolerMaster HAF 932 modified
    Power SupplyCoolermaster SilentPro Hybrid 1300W
    Keyboard Razer Black Widow Ultimate
    Mouse Razer Ourobouros
    Headset Razer Tiamat 7.1
    Mouse Pad Razer Exact Mat
    OS Windows 10
    Network RouterISP provided (Free)
    Accessory #1 Razer Hydra
    Accessory #2 Madcatz Arcade Fightstick
    Accessory #3 Belkin n52te
    Granger's Avatar
    Dec 2011
    Location
    France
    25
    419
    Have you tried ram coolers like the G-Skill Turbulence fan cooler (or Corsair equivelent)?
    Because until now, everything I have read about watercooling RAM said that it was less efficient than the RAM Fans and put a lot of resistence in the loop.
    Seeing your test, proves (at least for your system) that these water blocks work well to cool the RAM, I am now going to try and find a test waterblocks against Fans for cooling RAM (if one has been done) because I have only been going on heresay until now concerning the RAM and WC.
    edit: I'm using the Turbulence II on my RAM at the moment. Need to find a probe to test the temperatures with an without
Tags for this Thread
