10-03-2012 05:17 AM - last edited on 03-06-2024 07:11 PM by ROGBot
10-03-2012 05:50 AM
10-03-2012 06:00 AM
10-03-2012 06:22 AM
10-03-2012 06:21 AM
10-03-2012 08:11 AM
10-03-2012 08:21 AM
kkn wrote:
IF you will, you can downgrade te mobo to the m5f, only difrence is LN2 ( extreeme overclocking ) and an extra pcie slot.
the extreeme is fo rthe real entusiast OC'er realy, the m5f is gamers whit an extra need and m5g is for gamers whit a normal need ( lets say max 2 screecards if wanted whit out enny other expansion optional )
chrsplmr wrote:
Awesome .. Welcome to ROG..
Take a look at the storm trooper .. exactly the same size as the x .. but much more versatile..
just hands down better .. imho.. (the hafX is on my desk) last builds have been the trooper..
as will be the next.c.
10-03-2012 08:36 AM
10-03-2012 12:15 PM
Racer Of All wrote:
Hey everyone,
- The PSU I bought is recent. I got it before I decided I was going to put together this build (bought it alongside my GPU). After these purchases I'll be really tight on cash for a while so my question is -- how severely do I need to connect the secondary 4-pin connector on the mobo? I will do some overclocking but nothing too extreme.
- I heard about the 'tape' trick with the cooler I'm getting so it does not short out the video card, would duct tape be good for that purpose? Otherwise what should I use?
- This is just more of a 'confirmation' but can the Maximus V Extreme do voltage control for CPU fans? I'm asking because that will decide whether I get the regular NH-D14 with 3pin fans or get the NH-D14 SE2011 and then a mounting kit because it comes with 4pin fans for PWM support.
