Results 1 to 5 of 5
    ROG Member Array
    Feb 2012
    17
    3 Projector Eyefinity
    I want to set up an eyefinity group on my gaming rig with 3 projectors. Looking at projectors i saw that full hd projectors on
    newegg are upwards of $800. Does anybody know of cheaper hd projectors, more in the 4-500 dollar range? I will consider the more expensive ones if I have to. Also does anyone have any tips for me? I plan on gaming and watching TV, netflix, and movies on this setup.
    iron man Array kkn's Avatar
    Aug 2011
    Location
    norway
    218
    5,885
    wow i must say, how do you gona set up all 3?
    i would recomend to go on a AV forum and ask or look around, unless there are ones that have projectors here on the forum.
    you have to think of the light, lag, +++ when seting up projectors ( as i guess you know )
    mabye start whit one and add on more laters?
    ROG AirWays Captain Array TenBlade's Avatar
    Oct 2012
    Location
    Denmark
    45
    815
    I can recommend Wide Screen Gaming Forum if there´s no help here.
    http://www.wsgf.org/forums/multi-mon...or-discussions
    Good luck with your build, let us know how you progress
    Bjorn
    ROG Guru: Blue Belt Array sectionate PC Specs
    sectionate PC Specs
    MotherboardAsus Crosshair V Formula
    Processor8350 - 1090T
    Memory (part number)G Skill Sniper F3-14900CL9-4GBSR
    Graphics Card #1Asus GTX660-DC2O-2GD5
    MonitorAcer GD235HZ - ViewSonic VX2439wm - SyncMaster P2350
    CPU CoolerCorsair H100i
    CaseHAF 932
    Power SupplyCorsair Professional HX850
    Mouse Zowie EC1 eVo
    OS Microsoft Windows 7 Enterprise 64bit
    sectionate's Avatar
    Feb 2012
    Location
    Florda
    57
    869
    +1 wsg forums is your best place to ask
    Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - ViewSonic VX2439wm - Acer GD235HZ - SyncMaster P2350 - PowerColor Red Devil RX 480 8GBD5-3DH/OC - Current Mode: 5760 x 1080 - (retired) ASUS GTX660DC2O2GD5 - Nvidia 3D Vision Wired - HAF 932 - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)G73JH, Lenovo Y500 SLI
    MotherboardASUS Maximus IV GENE-Z
    ProcessorIntel 2600K
    Memory (part number)16GB DDR3 1600
    Graphics Card #1GTX980
    MonitorBenQ BL3200PT
    Storage #1Patriot PyroSE SSD
    CPU CoolerCustom WC loop
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    177
    5,674
    Try to find somewhere they have projectors set up for demo. You might find that you don't actually need a full HD projector if your projection size is relatively small. 3 1024x768 projectors can still create a pretty good image and it's still more lines than 720p. They're a ton cheaper!
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
Tags for this Thread
