Problems with Maximus 4 Extreme
Joshua_Mahr
If i try to set the multiiplier to anything higher than 34 the board will not load the OS (win 7 64-bit). Post code it stops on is AE (legacy device).
i7-2600k
GSkill DDR3-1600 8-8-8-24 2x4G
M4E
ASUS GTX580 DirectCUII
Corsair 850HX
Vertex 2 60GB
ASUS DVD-RW
NH-D14
Dragon Rider
Both Drives on Marvell Sata III
Mem in slots 2 and 4
24pin - 8 pin - both molex conected to board
Foo-IX : i7-3730k 4.6Ghz/ HAF XB/ASUS Z77 Deluxe-V/ Trident X DDR3-2400 4Gbx2/ HD7970 Crossfire/ SeaSonic Platinum 1000W/ H100/ Vertex4 SSD/ 3x ASUS 23" LCD-LED
11 REPLIES 11
Raja
i7-2600k
M4E
Corsair 850HX
Vertex 2 60GB
ASUS DVD-RW
NH-D14
Dragon Rider
What BIOS version are you using?
If AE is being displayed at the POST splash screen - leave the board there for up to 2 minutes - let me know if it eventually tries to boot the OS.
-Raja
Dont know why this is but I had an Idea. I moved the two sata drives off the marvell to the intel sata3 ports and disabled the marvell and now it boots? Any Idea why?
Sorry I missed this post. Seems like there is some kind of detection issue.
Joshua_Mahr
Bios 1303
Left it there for over 5 min. No luck.
Joshua_Mahr wrote:
Bios 1303
Ok can you post a BIOS template or take screenshots from within UEFI and post them up so I can see what the board is setting for voltages and memory timings.
Use this and fill out the settings you see:
CPU Level Up
AI Overclock Tuner
BCLK/PCIe Frequency
Turbo Ratio
Maximum Turbo Ratio Setting
Internal PLL Overvoltage
Memory Frequency
Memory Bandwidth Booster
APU Power Saving Mode
DRAM Timing Control
List the first section of Timings please
CPU Voltage Offset/Manual
CPU OFFSET/Manual Voltage
DRAM Voltage
VCCSA Voltage
VCCIO Voltage
CPU PLL Voltage
PCH Voltage
PCH PLL Voltage
Skew Driving Voltage
CPU Spread Spectrum
Joshua_Mahr
Well thanks anyways. I will do some overclocking later I will post with some results later. Thanks!
Retired
Not applicable
I have a question for you.Did your sistem work fine before you start to overclock the cpu?I ask that because for every work fine for me until I start to overclock the cpu.Mayde I have the same problem like you.
Yes. It would work just fine until OC'ing. I just moved the two drives down a port to the Intel 6 rather than the Marvell and perfect.
If you are looking at the Mobo. If you have it in the top 2 red ports move it to the bottom red ports and in the BIOS disable the Marvell controller. System has been flawless since.
Retired
Not applicable
wow!!!
I know there is a new rom on the site for one of those two SATA controllers did you try that?
