Results 1 to 6 of 6
    ROG Enthusiast Array wolfy PC Specs
    wolfy PC Specs
    Laptop (Model)MSI GS6QD Ghost
    MotherboardROG Maximus VIII Formula
    ProcessorI7 6700k skylake
    Memory (part number)4x 4 GB kingston hype X DDR4 @3000mhz
    Graphics Card #1MSI 980TI gaming 6GB
    Monitordell 34" curved+23"ASUS +21" iiyama touch
    Storage #1500GB M2 kingston
    Storage #22 x 250GB ssd ocz
    CPU CoolerEKWB watercooling
    CasePhanteks enthoo Primo
    Power SupplyCorsair 1000W
    Keyboard Razor Black widow Chroma
    Mouse Razor Mamba Chroma
    OS Win 10
    Jun 2011
    Location
    Denmark
    12
    74
    Touchpad way to sensitive
    How can you adjust the sensitivty of the touch pad just very lightly putting my finger on in causes it to react
    on my older laptop you adjust the pressure on it, but i cannot find that any where in Win 8.
    its causing me so much hassle!
    ROG MAXIMUS VIII FORMULA
    CPU: Intel 6700K @4.5 ghz
    4X8GB fury x ddr4 ram @3000
    1 x MSI GT980TI gaming 6gb
    1x 500GB Samsung M.2
    1x 500GB Crucial SSD
    2 X 256GB OCZ SSD
    1000w PSU from corsair
    tower phanteks enthoo primo
    1 x dell 34" curved + 2x 20"
    cpu +980TI are all water cooled by EKWB
    ROG Guru: Blue Belt Array
    Apr 2012
    23
    878
    which model notebook are you using?
    Re-install about touchpad driver and re-set or correction have any improve?
    AntiMatter Guru ROG Array chrsplmr's Avatar
    Jul 2011
    295
    6,111
    Oct 2012
    20
    42
    Quote Originally Posted by chrsplmr View Post
    I'm having a tough time with my TouchPad after updating to Windows 8 as well. My biggest problem is the cursor will intermittently just stop, or pause, as I am trying to move it across the screen, often making me pick up my finger and restarting repeatedly juts to make it across the 1920x1080 screen one time. I think this happens as my finger starts to flatten out (not juts pressing with the tippy tip of my finger) and maybe it starts thinking I now have two or more fingers there, IDK. So I tried disabling 2 and 3 finger support options, but it still feels quirky. Sometimes the cursor seems to teleport around too, and I do have tapping turned off so its not because of that. It reminds me of playing Asteroids in the old days, a little triangle ship going hyperspace around the screen, lol. But it's a real pain, this is the worst touchpad experience I have ever had, hopefully I can solve it.
    As far as you links go, I downloaded and installed the Microsoft package there, but it is only for Microsoft Mice and keyboards, so it doesn't help with the touchpad. That article is rather old, and he solved his problem with different drivers, which are now probably old. And for some reason I can't download any of those drivers from Synaptic's site; but I'll keep trying.
    I am currently using the latest driver from Asus, BTW, this one: Version V16.2.11.7. There doesn't seem to be any adjustment for sensitivity in it, only buttons to turn on or off certain features.
    ROG Guru: Gold Belt Array dstrakele's Avatar
    Sep 2011
    Location
    USA
    89
    4,437
    If you UNinstall your current touchpad driver and reboot to let Windows 8 install its Plug-N-Play touchpad driver, does that work any better for you?
    If not, your touchpad may have a grounding issue as reported for some G73 and G74 touchpads. Erratic cursor movement during normal use (not while typing) is one of the symptoms.
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
    Oct 2012
    20
    42
    Quote Originally Posted by dstrakele View Post
    That didn't really help much, however, I installed this driver after that, and after some customizing, everything is GREAT now; night and day difference in control.
    I got the idea from madnj in this thread: http://rog.asus.com/forum/showthread...light=touchpad.
    He then installed the latest ASUS Win 8 Synaptics driver over top of it to get gestures working; which I haven't done yet but maybe I will experiment later. I've never really used gestures, so I don't know what I'm missing there, but I do know what I was missing with no control, and now I have that back, so I'm counting my blessings at this point.
