+ Reply to Thread
Results 1 to 2 of 2
Thread: temp limitations and benchmark procedure
    hello there,
    first of all: i'm new to this forum and hope people from austria are as well welcome as my occasional bad spelling or my greenness for it is my first sandy bridge build
    i recently assembled a new system, which is running stable @ 4,5ghz, and now have a few questions for i'd like to max it out. would be obliged, if you could help me or at least give me a few hints...
    - what should be the max temps for i7 2600k without ruining the cpu in a long term? at the moment (see signature) my cpu temp ranges from 39-40°c with core temps between 55°c and (rarely peaking out at) 63°c (benchmarked with aida64). are these values actually ok? => i'm planning to stick to this system for approx. 2 years, if possible...(with minor changes of course).
    - how do i "securely" find out what frequency my cpu is capable of?
    - can you recommend a concrete benchmark procedure? how long should i run aida64, 3dmark vantage, prime, etc. for a reliable value? particularly in which sequence?
    thanks in advance and greets from vienna!
    mive | core i7 2600k @ 4,5 | antec h2o 920 (mod) | corsair vengeance 8gb @ 1866 | msi 580gtx lightning @ 900 | ocz vertex 3 120gb | seagate barracuda xt 2gb | powered by thermaltake toughpower grand 750w | staring @ asus 236h
    ROG Guru: Orange Belt Six Foot Ginger +10
    May 2011
    Location
    Folsom CA FTW
    493
    wow there is allot to say here
    that part will start to step down clock speed at 80 C so keep it under that temp, If its in the 60 C range under full load for a long time that's just fine.
    If you want to make the part last, put the voltages back to stock. Voltage kills CPUs
    plug in your batch number off of the box or your CPU and there will be link telling you roughly what that batch is capable of OC wise.
    Run each of those for say two hours each and let it prime for a day. If nothing fails that system is rock stable.
    Intel Core i7 Extreme 980X @4.2
    Rampage III Formula
    Corsair DDR3 2000 Dominator at 1600 7-7-7-20 at 1.5 volt
    Intel 320 Series 300 GB SSD
    Corsair Graphite 600T
    Corsair H70
    Corsair AX1200 watt
    2x Asus 580 CU2 at 840/4100
+ Reply to Thread
Similar Threads
  1. high temp on NB ?
    By Offpiste in forum Rampage Series Motherboards
    Last Post: 10-03-2012, 09:47 AM
  2. G73SW-3DE normal idle temp's...
    By jorlanm in forum Older G Series Notebooks
    Last Post: 05-19-2011, 03:15 PM
  3. AI suite cpu temp sensor
    By Harman Chester Castello in forum Rampage Series Motherboards
    Last Post: 03-02-2011, 06:50 PM
  4. crrosshair 4 formula nb&sb normal temp
    By clyde080808 in forum Crosshair Series Motherboards
    Last Post: 02-08-2011, 06:37 PM
  5. Another new R3E member to the scene + a temp question
    By godslayer in forum Rampage Series Motherboards
    Last Post: 01-02-2011, 03:54 PM
