2nd hard drive install
Retired
Not applicable
i just installed a momentus xt hhd in my g53sw and i was wondering how to get rid of the stupid partitions and at least move the os files onto the new hhd without deleting any data
5 REPLIES 5
reiyu
i personally use norton ghost to capture an image first, then wipe the hard drive clean including the partitions, and then restore the image. there could be some free software out there but i never used anything aside from norton ghost, so i wouldn't know.
Retired
Not applicable
You can use disk management on windows 7 to remove partitions. I've used xxclone with great success for cloning drives, and its free.
Area_66
Level 11
CloneZilla will do it too.
Retired
Not applicable
ok i used xxclone, can i just delete the old files even if they are os files?
Chastity
After you are done cloning the original drive, and it's working properly, you can delete the old partition make a new one.
[SIGPIC]Kicking Ass Since Today[/SIGPIC]
