+ Reply to Thread
Results 1 to 5 of 5
Thread: Crosshair V + reboot/shutdown hang ups
    ROG Enthusiast Prolab +10
    Jun 2011
    Location
    Toronto, ON
    29
    So i got my CH5 a few days ago and i started with a clean install of Win 7 pro. Downloaded the recent drivers/BIOS (0404) from Asus website, installed SP1 and important updates and so far so good.
    Ive been putting the rig to sleep so i never had to shut it down. But there was a few updates from Win 7 and required a restart. Went through the whole process and when you see the shutdown screen - it just stays there. I have to press the reset button to reset the computer.
    So after the update has been patched and installed - for **** and giggles, i wanted to shutdown the computer. Same thing, it just hangs on the shutdown screen.
    I have the power management on "performance". I believe i have the computer under UEFI on S1 shutdown (auto).
    Is there anything else im missing? Not too familiar with UEFI.
    System specs:
    965 BE OC @ 3.8
    8GB G Skill RAM F3-12800CL9D-4GBRL
    XFX 6950
    XFX BE 850 PS
    OCZ 60 & 120 GB SSD
    (3) 2 TB WD Green Drive
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,778
    Just to clarify, when you say that it freezes, how long did you wait? I've found that Windows will sometimes take a very long time to apply patches when shutting down. Not like all night but sometimes a good 5 minutes.
    ASUS Maximus IV GENE-Z Intel 2600K DangerDen cooling 8GB G.Skill Trident
    ASUS GTX670 Patriot PyroSE SSD Antec Signature 650 PSU Antec Mini P180 [ ASUS G73JH ]
    Folding@Home - Join us!
    Jun 2011
    Location
    Toronto, ON
    29
    Quote Originally Posted by xeromist View Post
    This is after the updates have been finish installing.
    Although there are times where i can shut down/reset by logging off then -> shutdown/reset and it works.
    Jul 2010
    Location
    Sacramento, CA
    4,778
    It could be a corrupted update. Sometimes you just need to clear the update cache. Here's the article on how to do it:
    http://support.microsoft.com/kb/193385
    Jun 2011
    Location
    Toronto, ON
    29
    Okay thanks, im going to try this when i get home tomorrow morning.
+ Reply to Thread
Similar Threads
  1. rampage III black edition don't reboot
    By radi in forum Rampage Series Motherboards
    Last Post: 05-28-2011, 12:56 PM
