Crosshair V - Intel(R) 82574L Gigabit - Network Problems
Retired
Not applicable
Hey,
I just got my Crosshair V 990FX, However i am having Internet / Network problems.
Currently i have no internet access or network capabilities.
Looking in the device manager and under Network adapters it shows the Intel(R) 82574L Gigabit Network Connection, but the device status says 'The Device Could Not Start (Code 10).'
I am also getting this message on boot up 'Intel Boot Agent GE V.1.3.5.1 PXE-E05 has not started. LAN NVM configuration corrupted or has not been initialized. The BOOT Agent cannot continue.'
I have installed and tried reinstalling the drives from the disk...but no change 😞
If anyone has some ideas i would be very thankful.
System:
ASUS Crosshair V Formula Motherboard 😄
AMD Phenom II X6 1100T BE 3.30GHz
Microsoft Windows 7 Home Premium SP1 64-Bit - OEM
Kingston HyperX Genesis Grey 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz
OCZ 550W Fatal1ty
42 REPLIES 42
Raja
CPurky wrote:
Hey,
System:
Akasa AK-CCX-4002HP Venom CPU Cooler
OCZ 550W Fatal1ty
Could be a faulty NIC. Is this a fresh OS install?
-Raja
Retired
Not applicable
-Raja
Yes formated the Hard Drive,then installed the Win7.
OK, if clear CMOS etc still gives you a code 10 in Windows, RMA the board please.
-Raja
Retired
Not applicable
-Raja
Unfortunately still no luck... thanks for your help but it looks like ita a RMA 😞
Shame.
Kipper
Go into the BIOS in Advance section, then On board hardware, and check to see if the LAN is disabled. You probably just need to enable the setting. I have seen this two times now.
Retired
Not applicable
Yer Unfortunately that was one of the 1st things i checked.
After a few more attemps last night i noticed if i clear the cmos then restart the computer with an ethernet cable plugged in. The ethernet ports Speed LED lights up orange until windows is booted. However after a computer restart it never comes on again unless i clear cmos.
Praz
If the LAN is disable in the UEFI it should not be showing in Device Manager as is stated in post #1.
Raja
I'd try for the RMA mate. If you're US based drop me a PM and I can help with that if need be.
One last thing not made clear in you opening post - this is a fresh Windows 7 install right? That can sometimes cause a code 10. If it is a new install then the code 10 is almost definitely a hardware malfunction.
-Raja
Retired
Not applicable
-Raja
I formated the hard drive using the advanced setup when installing Win 7 x64.
Unfortunatly im U.K base, Thanks for the help tho.
