+ Reply to Thread
Results 1 to 4 of 4
Thread: Rampage III Extreme Problem
    Hey I had my system up and running fine for about 9 months, then a few days ago I bought a new case and put it all into that, a Lian-Li X2000F and installed water cooling for the CPU. Now I can't get it to boot into Bios at all. When I turn it on I get the initial start up beep, then about 5sec later get a second identical beep, I can't find this code in the manual so I'm not sure what it means.
    I've taken out and reinstalled the RAM several times, also checked the PCIe connections, and used the switches to further test them. Then tried booting with only 3 of the 6 sticks of RAM in, to no avail. I also checked all the SATA connections and they all seem to be sitting nicely. Also tried clearing the CMOS with the handy button on the mobo, but that didn't help either.
    Any help with this would be very appreciated.
    System Specs:
    Mobo: Asus Rampage III Extreme
    CPU: Intel i7 950
    GPU: 2 x Evga 580 GTX
    RAM: 2 x DDR3 Corsair Dominator GT 2000 6GB Tripple Channel (CMT6GX3M3A2000C8)
    SC: Sound Blaster X-FI Titanium HD
    PSU: Silverstone ST1500 1500w Modular PSU
    Don't worry I fixed it, 1 of the 8pin CPU connectors was faulty, had enough to seem to boot, but not quite enough to get the job done.
    Not to be taken seriously Raja@ASUS +20
    Apr 2011
    Location
    ASUS North America
    2,800
    Glad you got it sorted
    ROG Guru: Orange Belt Six Foot Ginger +10
    May 2011
    Location
    Folsom CA FTW
    493
    that's not bad, the sound went bad on mine
    at least there was two so you had a back up.
    Intel Core i7 Extreme 980X @4.2
    Rampage III Formula
    Corsair DDR3 2000 Dominator at 1600 7-7-7-20 at 1.5 volt
    Intel 320 Series 300 GB SSD
    Corsair Graphite 600T
    Corsair H70
    Corsair AX1200 watt
    2x Asus 580 CU2 at 840/4100
+ Reply to Thread
Similar Threads
  1. Rampage III Gene Problem
    By Wynk in forum Rampage Series Motherboards
    Last Post: 01-09-2013, 10:14 PM
  2. asus rampage II third channel ram problem!!!
    By alexhats in forum Rampage Series Motherboards
    Last Post: 05-12-2011, 07:53 PM
  3. Rampage II Extreme - QPI Frequency Problem
    By connector in forum Rampage Series Motherboards
    Last Post: 05-09-2011, 08:57 AM
  4. Rampage Formula extreme boot problem
    By dittopb in forum Rampage Series Motherboards
    Last Post: 11-26-2010, 05:04 PM
  5. Rampage III Extreme vs Asus Rampage III Formula feedback?
    By dctokyo in forum Rampage Series Motherboards
    Last Post: 10-09-2010, 10:00 PM
