Results 1 to 9 of 9
Thread: G73-JH Max RAM
    New ROGer Array
    Jul 2011
    1
    G73-JH Max RAM
    I have the G73-JH model with the Intel I7-720 processor and was wondering what the max RAM was on it. While this may seem like a rather stupid question, since the information on the G73-JH page clearly states that the max RAM is only 8GB other websites with the same motherboard claim that the motherboard maxes at 16GB of RAM. I was wondering if someone could tell me if the information on the ASUS page is out of date or not, so I'll know if I am wasting my money on the extra RAM or not.
    Note: I'm well aware that the RAM in my computer probbably isn't my bottleneck, all the same I would like to know if the RAM would work in my computer.
    ROG Guru: Orange Belt Array jorlanm's Avatar
    Apr 2011
    Location
    Mssion Viejo
    314
    the spec says 16GB max...But like Alienware that has 4 mem slots that says it will support 32GB...so Im pretty sure the JH JW SW SX models will support 32GB as well..
    -ASUS ROG G73SW-3DE-
    -Intel Core i7-2630QM Mobile Quad Processor
    -Intel HM65 Express Chipset +ICH10
    -17.3" 1920x1080 120Hz Anti-Glare Matte Screen
    -nVidia GeForce GTX 460m 1.5GB GDDR5 VRAM
    -nVidia 3D Vision Active Shutter Glasses
    -Creative EAX Advanced HD 5.0
    -THX TruStudio
    -8GB DDR3 1333MHz RAM (Max 32GB)
    -2x500 Seagate Momentous XT Hybrid HDD
    -Blu-Ray 4x Burner
    -Logitech Performance MX Darkfield Laser Mice
    -Microsoft Windows 7 Ultimate
    -XBOX360, PS3, Wii
    ROG Member Array
    May 2011
    Location
    Kerala, India
    20
    has anyone tried putting in more than 16gb ram? Do you get single 8gb ram sticks?
    Asus G53JW-A1 | Intel® Core™ i7-740 1.73-2.93GHz| 8GB RAM | NVidia GTX460M | 750GB@7200rpm | 15.6'' 1920x1080
    Toshiba Satellite A500-134 | Intel® Core2Duo™ P8700 2.53GHz| 4GB RAM | ATI Mobility Radeon™ HD 4650 | 500GB@5400rpm | 16.0" 1366 x 768
    Toshiba NB100-111 | Intel® Atom™ processor N270 1.6GHz | 1GB RAM | Mobile Intel® GMA 950 | 120GB@5400rpm | 8.9" 1024 x 600
    Toshiba Satellite Pro L100 (5 years old and still works fine!!!)
    ROG Enthusiast Array
    May 2011
    Location
    Bucuresti
    25
    8GB sticks are obscenely expensive but should be on market already and, according to intel specs, the memory controller from the cpu should be able to deal with them.
    So yea, 32Gb mite be useable provided you use the appropriate OS as in x64 W7 Professional, Enterprise or Ultimate. Home Premium for example is limited to 16GB ram.
    G53JW-IX045V, i5-460m, 6GB DDR3, GTX 460m, 3D Vision 1366x768, SSD Corsair F120 + hdd 500GB/7200
    Verde 275.33 WHQL @stock clocks ** 3D Mark 11 - P1864 *** 3D Mark Vantage - P8666 **
    TeamROG Notebook Member Array Chastity@ASUS's Avatar
    Oct 2010
    Location
    California
    18
    1,334
    You should be able to use 8GB sticks with i7 units, not i5.
    Kicking Ass Since Today
    May 2011
    Location
    Bucuresti
    25
    Memory specs are the same. The only difference is max frequency which is 1333 for i7 and 1066 for i5
    http://ark.intel.com/Compare.aspx?ids=49024,50179,
  7. #7
    ROG Member Array
    May 2011
    Location
    Kerala, India
    20
    But isn't 32gb overkill?
  8. #8
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)G73JH, Lenovo Y500 SLI
    MotherboardASUS Maximus IV GENE-Z
    ProcessorIntel 2600K
    Memory (part number)16GB DDR3 1600
    Graphics Card #1GTX980
    MonitorBenQ BL3200PT
    Storage #1Patriot PyroSE SSD
    CPU CoolerCustom WC loop
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    177
    5,674
    Quote Originally Posted by FlyingFalcon View Post
    Yes. Most of the things that can utilize that much memory are also very CPU intensive. A laptop CPU just couldn't keep up with those use cases. Still, it's nice to have a theoretical limit far above what you'll ever use just so that you know it will never be an issue.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
  9. #9
    Oct 2010
    Location
    California
    18
    1,334
    Quote Originally Posted by manu72 View Post
    According to that page, my G73SW-A1 shouldn't have 16GB and have 25 GB/s memory speeds, but it does.
    I'm just trying to say that specs and limits have changed since they made the data in that database.
