Hi, I recently finished my build and went straight into OCing to 4.8 per a guide on this forum by you and after I follow the guide to the end, I reboot and went into windows itself. To confirm the OC, I used the ROG - CPUID and saw that the processor is still running at stock 3.4ghz. Another thing, hyper-threading is enabled but CPUID shows 4 instead of 8 threads. here's the link that I used and I followed the quick OC guide
http://www.asusrog.com/forums/showth...clocking-Guide
My setup as follows
i7 2600k
Maximus IV extreme B3 revision / Bios 1303
Matrix Platinum gtx 580 OC to 925ghz / 1.150v
Corsair XMS 3 4x4gb 1600C9
H70 cooler
Thanks, Max
