+ Reply to Thread
Results 1 to 2 of 2
Thread: How to put out cmos battery on G73JH??
    Lightbulb How to put out cmos battery on G73JH??
    Hi Guys.. Please Help me...T_T
    I have bricked my g73jh during bios update..
    it goes well until finish bios update..
    but after finish that , power gone out..
    and I can't turn it on anymore..
    even I can't see any blue light..
    It's completly dead......
    So I search on google... and found something that
    I can fix through reset cmos by put out cmos battery..
    So i'm about to begin unassembly it..
    Please save me.....
    ROG Guru: Yellow Belt irdmoose +20 irdmoose's Avatar
    May 2010
    Location
    Orangevale, CA
    151
    Sounds like you had a bad flash, and resetting the CMOS probably won't fix it. I believe the procedure to reset the CMOS is to unplug the system battery and the power adapter, and press the power button 5-10 times, then reconnect everything.
    It looks like the CMOS battery is buried inside the unit, and you'll have to disassemble most of the computer and remove the motherboard to get access to it (unless there's an easier way that I'm not seeing). There's a great how-to video done by BTOTech here. That should walk you through the teardown for any G73 model laptop (including the SW's). Be careful though. If your laptop is under warranty, I would send it in since Asus covers bad BIOS flashes under their warranty.
    I'd be willing to bet money that pulling the CMOS battery and resetting the CMOS won't fix your problem in this case, but it's your call. HTH.
+ Reply to Thread
Similar Threads
  1. G73jh having battery problems
    By pnikkosis in forum Older G Series Notebooks
    Last Post: 06-15-2013, 10:51 PM
  2. [problem] N73jq-A2 won't power up, CMOS battery with bad solder
    By rdany62 in forum NON-ROG ASUS Notebooks and Tablets
    Last Post: 07-21-2011, 07:46 PM
  3. G73JH-A1 Battery problem - Not working anymore, but loaded.
    By Ferodon in forum Older G Series Notebooks
    Last Post: 06-22-2011, 05:04 PM
  4. Power/Battery question
    By Crispy in forum Older G Series Notebooks
    Last Post: 05-30-2011, 06:29 AM
  5. G73JH - Right fan cooling at 100% all the time, even on battery
    By tsfdeymos in forum Older G Series Notebooks
    Last Post: 05-24-2011, 04:51 AM
Tags for this Thread
