+ Reply to Thread
Results 1 to 10 of 10
Thread: VGA post light stays on Crosshair V
    I bought a crosshair v two weeks ago set it up in my system and flashed to the latest bios 0506 to gain some stability.
    After the flash It was running fine until the other day I was playing dirt 3 and my pc crashed when I reset the system it would not post.
    On checking the motherboard I saw the VGA post light was staying on which indicates a problem with the graphics cards.
    I have checked both cards in another system and they are ok but when I put them back in the crosshair v board it will not boot.
    I have tried one card at a time in both pcie x16 slots but still nothing.
    I have tried resetting the cmos but the board still shows the vga light error during post checks.
    What I now think is that the pcie slots have broken, does anyone have any suggestions?
    My system specs are
    NZXT Phanton case
    AMD Phenom II 1100T
    Crosshair V bios 0506
    Thermalright silver shadow cpu cooler
    8gb Corasir Vengance 1866mhz
    Two Sapphire HD6950 2gb dirt edition twin fan running crossfire. On stock settings
    Corsair 1000w modular psu
    Thanks in advance.
    Steve
    Not to be taken seriously Raja@ASUS +20
    Apr 2011
    Location
    ASUS North America
    2,798
    Hi Steve,
    Have you checked the PSU and memory in another board? If both of those work, then I'd suggest you RMA the board.
    -Raja
    Hi Raja,
    Thanks for the response.
    I have checked the ram in another board and it is fine also.
    As for the psu I have not taken that out yet but everything looks fine with it, there is still power going to the board.
    Everything else is working - cpu, ram post ok it just stops on vga constantly.
    Regards,
    Steve
    Apr 2011
    Location
    ASUS North America
    2,798
    Hi Steve,
    Okay, if using one DIMM in the furthest slot (slot 4) after a CMOS clear does not encourage the board to POST then the only option left is to RMA.
    -Raja
    Hi Raja,
    I have already tried that one stick in red slot 4 and it still is not going past the vga light.
    Regards,
    Steve
    Apr 2011
    Location
    ASUS North America
    2,798
    I'd put in for an RMA Steve, you are eligible for an advanced shipment on these boards.
    -Raja
  7. #7
    Raja,
    Does that RMA advanced shipment apply to people in the UK also, I live in Scotland?
    Regards,
    Steve
  8. #8
    Apr 2011
    Location
    ASUS North America
    2,798
    Quote Originally Posted by Steve4CFC View Post
    Raja,
    Regards,
    Steve
    You will have to check with the UK RMA department Steve. They should have something in place.
    -Raja
  9. #9
    Raja,
    I have contacted technical support in the UK for a resolution to the problem.
    Many thanks for all your help.
    Best Regards,
    Steve
  10. #10
    Apr 2011
    Location
    ASUS North America
    2,798
    No probs Steve, hope it solves the problem.
    -Raja
+ Reply to Thread
Similar Threads
  1. Another CROSSHAIR V Formula Post / Boot challenge
    By Tim in forum Crosshair Series Motherboards
    Last Post: 07-19-2011, 08:12 PM
  2. G53SW starts but screen stays black
    By mohwner in forum Older G Series Notebooks
    Last Post: 07-13-2011, 06:09 PM
  3. Asus G73JH cpu stays underclocked at ~994 MHz
    By Decimus in forum Older G Series Notebooks
    Last Post: 06-08-2011, 11:21 AM
  4. keyboard back light
    By black_bishop in forum Older G Series Notebooks
    Last Post: 03-12-2011, 07:28 AM
  5. Light Issue
    By Fezteeny in forum Older G Series Notebooks
    Last Post: 02-09-2011, 07:26 PM
