I followed this great guide found
here.
My specs are identical - Maximus V Gene / i5 3570K / BIOS 1604
My build is found
here.
I followed Marshall's guide step by step, but Prime95 won't push past 3800 MHz.
😞I did save (F10) settings in BIOS each time. Confimed this when I rebooted on several occasions thinking I must have missed something. But after checking, double checking, triple checking - no go. Still only get 3.8. Windows task manager and AI Suite both show 100% CPU usage. Should this be 140% if I'm pushing to the desired 4.5? Is there a setting in Prime95 that needs to be told to push pass 3.8 or 100% ?
Please, any suggestions. I'm thinking it's a simple solution.
BTW, running Windows 8 64 bit (if that matters)
Thanks
