Some of you have reported that twinturbo does not work. Here is the fix:
Opened Command Prompt with Administrator rights and enter this:
- bcdedit /set useplatformclock true
- then Reboot
You can undo by entering:
- bcdedit /deletevalue useplatformclock
- then Reboot
From the benchmarks i tested off vantage, you can see the performance difference after this fix.
Before fix, twinturbo function would get lower benchmark scores:
vs
After fix, twinturbo is functioning properly:
vs
This has been tested on the G73Jh and should work for other models that have the turbo option. please let me know if you have had success with this fix and post some screen shots with your model here to further validate the fix.
Why does this occur? Windows 7 systems by default use the Time Stamp Counter (TSC), rather than the High Precision Event Timer (HPET) as the default timer during program execution. We are essentially enabling the HPET
