Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Renaissance Man Array Florre's Avatar
    Aug 2012
    46
    RAM Speed VS Latency
    What is more important ram speed or latency?
    2400mhz with latency 10-11 or 1866mhz with latency 9?
    CPU Intel i7 5960X@ 4.5Ghz
    RAM Corsair Dominator Platinum 32GB 2400mhz
    GPU 2 X EVGA GTX 980 in SLI
    SSD 2 X Samsung 850 Pro 1TB
    HDD 2 X WD RE 4TB
    MOBO Asus Rampage V Extreme
    PSU Corsair AX 1500i
    CASE Corsair 900D
    DISPLAY 2 X ROG Swift
    ROG Member Array
    Jun 2012
    18
    For what ?
    Gaming with a PCI-Express VGA ? None.
    Desktop usage ? None.
    A few applications ( WinRAR, 7-zip, WinZIP, KGB, SAP, high traffic SQL Server ) ? The best of both worlds, and also depends on the platform ( chipset + CPU )
    If you're talking about your system, and your primary usage ( which is gaming most likely with your GTX 580 SLI ) then... get a decent DDR3-1600 memory kit with the capacity of your desire ( anything from 6GB and more is the top you can get for gaming performance ).
    Data and proof to back it up ? Sure, go ahead and read my extended testing article
    http://www.benchzone.com/page.php?al...formance_part1
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    Location
    Mount Pleasant, SC, USA
    163
    7,967
    Regarding the system memory the most important is to have it running stable... a bad memory can really mess up things... - whatever settings you choose, run memtest86+ for at least 4 cycles, if it passes, then most likely you're fine...
    If you're in benching, then 2400MHz CL10 is better than 1866MHz CL9... - just be aware that not all systems are the same, and there is no guarantee that you can actually reach those memory speeds... (it's about the chip's lottery)
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Michelle Rudan...yes way!)
    MotherboardRampage V Edition 10
    Processori7 5960X @ stock day-to-day / 4.4GHz/4.4GHz cache Gaming / 5.1GHz/4.7GHz cache OC
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2GTX Titan X
    Graphics Card #3Not yet...
    Graphics Card #4At these prices?...Not likely :-(
    Sound CardXonar Essence STX
    MonitorDell U2711
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Monsta 480s, EK Supremacy Evo, Dual EK TitanX WaterBlocks
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    Location
    In the gutter but looking at the stars
    385
    10,976
    There is a formula that can help you in deciding if one kit is faster than the other when the timings are taken into account.
    (CAS/frequency) x 2000 gives you a number in nanoseconds for comparing speeds.
    Say you see a 1600 kit at 7-8-7-20 and a 1866 kit at 9-10-9-28 which is faster?
    Well 7/1600 x 2000 = 8.75 nanoseconds; 9/1866 x 2000 = 9.646 so the 1600 kit actually looks quicker.
    If these numbers are close or the same choose the higher frequency it will be more efficient.
    Mar 2012
    Location
    163
    7,967
    Arne, what you calculated there isn't the memory latency? If so, higher latency doesn't mean that your RAM is actually slower?
    So, 9.646 ns is actually worse than 8.75 ns... the first takes more time...
    MonitorDell U2711
    Apr 2012
    Location
    385
    10,976
    Correct! the latency is the CAS no..... the formula uses latency not calculates it......it lets you know which kit is faster when comparing different speed RAM with different latencies.... I thought Florre might have been wanting to know that (maybe my mistake).
    1866 cas 9.. 9.6462 slow
    2400 cas 11.. 9.1666 faster
    2400 cas 10.. 8.3332 fastest
  7. #7
    Aug 2012
    46
    Quote Originally Posted by Arne Saknussemm View Post
    Thanks for the formula. Its proving to be damn useful!
    Thx.
    HDD 2 X WD RE 4TB
    CASE Corsair 900D
  8. #8
    MonitorDell U2711
    Apr 2012
    Location
    385
    10,976
    Good stuff!
  9. #9
    ‎‎‎‎‎‎‎‎‎‎ Array Gorman's Avatar
    Apr 2012
    90
    627
    Could you explain this formula?
    Looking at the units I see CAS is in clock cycles, frequency is mega clock cycles per second, so the formula yields an answer in micro seconds.
    So where does the 2 come from? I'm guessing this is an approximate formula, and the real one uses a second point of data; (CAS+???)/F * 1000 ?
  10. #10
    MonitorDell U2711
    Apr 2012
    Location
    385
    10,976
    Not thought about it much... might hide a multitude of simplification but works as a comparative for kits I believe.
    Hmm but If CAS is measured in nano seconds divide by x thousand times y thousand still nanoseconds no?
    http://rog.asus.com/forum/showthread...l=1#post195744
Tags for this Thread
