Results 1 to 9 of 9
    ROG Enthusiast Array
    Jul 2011
    Location
    Melbourne
    48
    SSD for Maximus iv extreme z
    I was wondering which port should I connect my ocz vertex 2 120gb to the Maximus iv extreme z? because there are few types of sata ports there. I not sure which one is for ssd. can anyone help me out ?
    ROG Member Array
    Jul 2011
    Location
    Darlington, UK
    14
    Due to your drive been sata II i would connect to the grey sata ports below the red sata ports.
    Jul 2011
    Location
    Melbourne
    48
    so is ahci ? and I can not plug to the red one? grey = 3gb/s?
    Jul 2011
    Location
    London
    29
    the 4 grey ports are intel controlled 3gb/s and so any of these is fine for your vertex since it is 3gb/s. The first 2 red ports are intel controlled 6gb/s and the last two are either marvell or jmicron controlled 6gb/s ports (of which there aren't great drivers for windows). Ahci will probably work but you may need to start with ide in order for windows to recognise it during an install, (change it back to ahci after you have all the intel controller drivers installed in windows). Also before you install windows on an ssd make sure you have the latest firmware. My vertex 3 didn't work with this mobo until I updated it to 2.09 firmware
    Asus Maximus IV Extreme | Intel i7-2600K | Corsair Dominator 8GB (4x2GB) DDR3 - PC3-12800C9 1600mhz | eVGA 580GTX 3GB | OCZ Vertex 3 Sata-III SSD 120GB/WD Caviar Black HDD 1TB x2 | Corsair 600T White | Corsair AX1200 Gold | Asus/Sennheiser Xonar Xense | Bigfoot 2100 NIC | Windows 7 Ultimate 64
    Jul 2011
    Location
    Melbourne
    48
    my SSD had an issue now. when I was trying to install os on it, it freeze during the installation. on the other hand, I tried to install the os to my normal hdd. it's works fine.
    untouched Array Praz's Avatar
    Apr 2011
    Location
    Midwest, USA
    134
    3,755
    Set hot-plug to enabled for the port you have the SSD connected to.
  7. #7
    Jul 2011
    Location
    Melbourne
    48
    Quote Originally Posted by Praz View Post
    what does hot plug do? I think I did change to
    enablend
  8. #8
    Apr 2011
    Location
    Midwest, USA
    134
    3,755
    When set to enabled it disables slumber states for that port.
  9. #9
    Jul 2011
    Location
    Melbourne
    48
    thanks for the help guys. is Maximus iv extreme z good comparing to other board ?
Similar Threads
  1. Wake On Lan - Maximus IV Extreme
    By grey_hammer in forum Other Series Motherboards
    Last Post: 12-22-2011, 04:21 PM
  2. Maximus extreme-Z released?
    By Mr.Facko in forum Other Series Motherboards
    Last Post: 07-19-2011, 04:21 PM
  3. Maximus IV Extreme freezing
    By niggz in forum Other Series Motherboards
    Last Post: 06-16-2011, 10:42 PM
  4. Problems with Maximus 4 Extreme
    By Joshua_Mahr in forum Other Series Motherboards
    Last Post: 05-30-2011, 04:22 PM
  5. Maximus 3 Extreme SLI
    By Reaper in forum Other Series Motherboards
    Last Post: 02-25-2011, 07:50 AM
