+ Reply to Thread
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Crosshair V Formula 990FX help :(
    ROG Enthusiast CrazyMan212 +10
    Jul 2011
    Location
    South Beach
    28
    i have a problem every time i start a game screen goes black or green color don't know what to do
    i have test 2 video card a 580 GTX and 560 ti gtx same thing that screen come up so how do i fix this issue ?
    Asus Crosshair V
    AMD 1090T
    G.Skill 8 GB
    Ocz Vertex 3 Raid 0
    Evga 580 GTX
    Not to be taken seriously Raja@ASUS +20
    Apr 2011
    Location
    ASUS North America
    2,855
    Could be a GPU or system stability issue.
    What GSkill RAM is this? (GSKill 8GB does not tell us much).
    What BIOS version are you using?
    -Raja
    ROG Member Sp33d Junki3 +10 Sp33d Junki3's Avatar
    Jul 2011
    Location
    New Westminster
    21
    Have you tried a different cable?
    Have you tried a different PSU?
    __̴ı̴̴̡̡̡ ̡͌l̡̡̡ ̡͌l̡*̡̡ ̴̡ı̴̴̡ ̡̡͡|̲̲̲͡͡͡ ̲▫̲͡ ̲̲̲͡͡π̲̲͡͡ ̲̲͡▫̲̲͡͡ ̲|̡̡̡ ̡ ̴̡ı̴̡̡ ̡͌l̡̡̡̡.__
    My System Specs @ OCN
    Asus Crosshair V, AMD X6 1090T @ 3.6Ghz with Coolit Vantage, 4x G.Skill Flare F3-14400CL7D 7-8-7-24 @ 1800 with OCZ XTC Ram Cooler, XFX 5870 with AC Extreme 5870 + VRM-R3
    2x Corsair Force 115GB Raid 0 + WD Green 1TB + 1.5TB + Kingston SSD 30GB, Corsair HX750, Dell ST2410, HAF X, Asus Xonar STX, Superlux 668B, Zalman MC-1, Edifier S330D
    Jul 2011
    Location
    South Beach
    28
    G.Skill F3-17000CL9D-8GBXLD i also try other 2 GB ram F3-12800CL7D-4GBXM. i have switch video card between 580 GTX and 560 GTX.
    i have try 3DMARK 11 and it does crash at start also my bios 506 and i even clean CMOS still the same
    Asus Crosshair V
    AMD 1090T
    G.Skill 8 GB
    Ocz Vertex 3 Raid 0
    Evga 580 GTX
    CorSair HX1000
    Jul 2011
    Location
    South Beach
    28
    i just took whole system apart but still the same issue
    Apr 2011
    Location
    ASUS North America
    2,855
    Is your OS install on that RAID array?
    -Raja
  7. #7
    Jul 2011
    Location
    South Beach
    28
    Quote Originally Posted by Raja@ASUS View Post
    -Raja
    Yes it is.
  8. #8
    Jul 2011
    Location
    South Beach
    28
    i just did clean install of windows 7 on 1 tb drive and i did run 3DMark11 and screen goes like picture.
  9. #9
    Apr 2011
    Location
    ASUS North America
    2,855
    Do you still have the raid array active as a secondary drive?
    Try using a different PCIe slot for the GPU and see if the issue persists.
    Set memory parameters:
    Command Rate 2T
    Read to Read Timing 5 clocks
    Voltages:
    Set VDIMM manually for the specified voltage of the DIMMs
    Set CPU/NB Voltage to 1.20V
    Ensure system is at stock.
    -Raja
  10. #10
    Jul 2011
    Location
    South Beach
    28
    I took off raid. After installing new OS on 1 tb drive I did run 3dmark11 and screen come up like alway. but after 3dmark11 was done screen when back to normal.
+ Reply to Thread
Similar Threads
  1. ASUS ROG Crosshair V Formula - (AMD 990FX) - Overview
    By FlanK3r in forum Crosshair Series Motherboards
    Last Post: 09-06-2011, 07:25 PM
