+ Reply to Thread
Results 1 to 8 of 8
Thread: Maximus Gene-z PCIe and Memory Slot issue
    New ROGer Helish +10
    Aug 2011
    Location
    Lake Mary
    4
    Unhappy Maximus Gene-z PCIe and Memory Slot issue
    So i just got my Gene-z board, got everything put together and at first couldn't get the board to post, eventually by putting the memory in slots A1/A2 it would post, but no dual channel. Also once windows was setup it was apparent that my second video card wasn't working/showing up at all. I checked the bios and it's not listed under the gpu/dram listing and not shown in windows device manager. I tried reversing the cards, and the outcome was still the same. When i tried just using the second slot, i had the same results, it booted but no video display ever kicked on. I am using (2) GTX460 1gb video cards (asus branded), 8gb DDR3 G.Skill Sniper ram and i7 2600k.
    So far i have not tried updating the bios to the latest, but i've tried the usual cmos clear, set defaults, remove power to no avail...
    Any ideas?
    Not to be taken seriously Raja@ASUS +20
    Apr 2011
    Location
    ASUS North America
    2,798
    Using one module of DRAM, update the BIOS to the latest and see if this helps.
    -Raja
    Aug 2011
    Location
    Lake Mary
    4
    Ok, all updated to the latest bios. Once I throw the second stick in I get stuck at debug code 38, even with the mem ok function enabled. If I move it to the slot to run single channel, it boots fine. And I still only show one card in the bios and windows.
    Apr 2011
    Location
    ASUS North America
    2,798
    What's the rated speed of the DIMMs?
    Also what CPU cooler are you using?
    -Raja
    Aug 2011
    Location
    Lake Mary
    4
    The memory is ddr3 1333 (10666) and the cooler I am using is the thermalright venomous x
    ROG Guru: Orange Belt Spathi +10
    Jul 2011
    Location
    Australia
    370
    What is the Sniper model?
    Maybe enable the XMP and see if it works better?
    If you still stuck (Unless it is another problem), Sniper F3-12800CL9D-8GBSR2 1.25V is cheap and probably/maybe good for Ivy Bridge later.
    Also, I would be testing with this...
    http://www.memtest.org/#downiso
    I am going to try 16Gig of F3-12800CL9D-8GBSR2 tonight.
    Maximus IV GENE-Z, 2600k, 16G Sniper F3-12800CL9D-8GBSR2 1.25V, 6870 Frozr II/OC, 2x 512GB Crucial M4
  7. #7
    Aug 2011
    Location
    Lake Mary
    4
    The Snipers model number is F3-10666CL9D-8GBSR. So far nothing has been able to get it to run in the A1/B1 slots, only A1/A2. I was able to get an RMA arranged last night since nothing seemed to be working for the Video card issue....Hopefully that will resolve all the issues
  8. #8
    Jul 2011
    Location
    Australia
    370
    p.s. in case someone wondered, 16Gig of F3-12800CL9D-8GBSR2 worked well, passed memtest. Memory runs 10% faster with 16G for some reason.
+ Reply to Thread
Similar Threads
  1. 2 way SLI PCIe slot placement
    By Sequincer in forum Maximus Series Motherboards
    Last Post: 11-01-2011, 06:46 PM
  2. Maximus IV Gene-Z Expansion Slot Configuration?
    By Synomenon in forum Maximus Series Motherboards
    Last Post: 07-19-2011, 09:14 AM
  3. Is it possible to have 1x 4890 @ PCIE Slot 2 to run at 16x?
    By godslayer in forum Rampage Series Motherboards
    Last Post: 03-18-2011, 11:08 AM
  4. Is changing PCIE slot order possible?
    By icecube in forum Rampage Series Motherboards
    Last Post: 03-11-2011, 07:14 AM
  5. Best PCIE slot for OCZ Revo on P8P67 Deluxe board
    By shotosan in forum NON-ROG Intel Motherboards
    Last Post: 01-15-2011, 05:25 AM
