Results 1 to 6 of 6
    New ROGer Array
    Apr 2013
    2
    help with opt 1 fan warning for crosshair v formula z-fx 8350 build
    hey,i m new to this forum..in fact this is my first gaming rig..i bought the build yesterday..i m facing some problem:
    my build:
    amd fx 8350
    crosshair v formula-z
    8gb corsair vengence
    corsair gs600 smps
    corsair 400r cabinet
    saphire radeon hd5450 gpu
    cooler master 120mm fan(cabinet)
    whenever i am opening windows i m getting a warning message that opt 1 fan speed --------- rpm..what is the problem?is my system getting hot(due to less power 600w)?plz help..is this natural?
    i have another thing to know,i have heard from a friend of mine that a the gpu i bought may hamper my motherboard as it doesn't have any fan...do i have to change?plz tell me early..i have 6 days to exchange.(plz also tell nvdia/amd will be better for this board)?
    ROG Guru: White Belt Array lewybear PC Specs
    lewybear PC Specs
    MotherboardRampage iv black edition
    Jan 2013
    Location
    Farnham, Surrey
    109
    Firstly welcome to the best community there is! Now the fan warning is due to AI suite it's rubbish don't use it seriously everyone will tell you that! And the fact your card has no fan doesn't matter the cards designed that way! Just pick a card you can afford and will do what you need, it's all personal choice.
    Enjoy owning the hardware it's sweet and always ask if you have problems, that's what we're for :-)
    I7-4930k @ 4.6ghz
    Avexir blitz 1.1 32gb @ 2400mhz
    NZXT X61 Kraken 280mm rad cooler
    Corsair ax1200i psu full white cable set
    Samsung EVO 850 128gb SSD boot
    Samsung EVO 850 1tbx4 SSD raid, storage
    GALAX GTX970 Infinity black edition, OC/UK editionX3 Oc-1.6ghz
    NZXT Phantom 820 full fan set
    ROG frontbase
    Samsung 55" 600hz (140hz effective) smart 3D tv as monitor
    Windows 7 pro 64bit
    ROG Enthusiast Array
    Dec 2012
    Location
    Lakeland, Florida
    39
    I use it and have no issues now. Go into the fan xpert and choose chassis fans on the drop down menu, then set it to standard on the other menu, mine was disabled factory. That will rid you of that annoying warning.
    Motherboard--Crosshair v Formula Z
    CPU--------- AMD FX 8350(stock clock)
    Video Cards----ASUS 7970 HD DC2-3GD5 x2
    RAM---------AMD RADEON 16 GB
    POWER SUPPLY-CORSAIR AX 850 PRO
    STORAGE----- WD GREEN 320 GB
    BACK UP DRIVE 320 GB (MORE WILL BE ADDED)
    OPERATING SYSTEM--WINDOWS 8.1 PRO
    CHASSIS-------THERMALTAKE LEVEL 10 GT
    ROG Guru: Blue Belt Array sectionate PC Specs
    sectionate PC Specs
    MotherboardAsus Crosshair V Formula
    Processor8350 - 1090T
    Memory (part number)G Skill Sniper F3-14900CL9-4GBSR
    Graphics Card #1Asus GTX660-DC2O-2GD5
    MonitorAcer GD235HZ - ViewSonic VX2439wm - SyncMaster P2350
    CPU CoolerCorsair H100i
    CaseHAF 932
    Power SupplyCorsair Professional HX850
    Mouse Zowie EC1 eVo
    OS Microsoft Windows 7 Enterprise 64bit
    sectionate's Avatar
    Feb 2012
    Location
    Florda
    52
    829
    Crosshair IV 1090T 4093.7 - Crosshair V FX - 8350 Batch # 1243PGT 4.422MHz - 4816.08 MHz 1.5v - GSKILL F3-14900CL9D-8GBSR(x2)1087.6 11-12-10 1.5volts - XFX (2) HD5750 - ViewSonic VX2439wm - Acer GD235HZ-SyncMaster P2350-Current Mode: 5760 x 1080 - ASUS GTX 660 Top - Nvidia 3D Vision Wired - HAF 932 - Scythe Ultra Kaze fans - Corsair HX850 - Corsair H100i - latest quakelive.com - Day thirteen 60fps - as always I'm powered by Futurelooks.com
    New ROGer Array
    Apr 2013
    2
    thanx man..it helped..really looking forward what this board can give with fx 8350 :-)
    Dec 2012
    Location
    Lakeland, Florida
    39
    Did you uninstall AI suite? Or did you change the fan option? I am using the 8350 on my build, it runs great, I havent gotten into tweaking it yet tho, I need a better cpu cooler first.
