+ Reply to Thread
Results 1 to 4 of 4
Thread: My Maximus4 eXtreme-Z always reboot.
    New ROGer Bigou +10
    Aug 2011
    Location
    France
    2
    Unhappy My Maximus4 eXtreme-Z always reboot.
    Hello, folks!
    I've buy a Maximus4 Extreme-Z, (or "M4XZ" for short) mainly for provided connectivity.
    On first boot, the M4XZ asks me to set the "EFI BIOS". (Nothing strange until now.)
    But after I've set, my computer reboot after 5s (more or less), shut-down and reboots after 1 or 2 sec.
    I've already tested to enable then disable the LN2. The Q_Reset to, and It’s not more effective.
    My configuration is in my Signature
    Have you any idea to helping me?
    Already, thanks!
    (And please, no acronyms or abbreviation without explanations for them, English isn't my native language, unfortunately for you.)
    MotherBoard: Asus Maximus4 Extreme-Z
    CPU: Intel Core-i7 2600 (LGA1155)
    GPU: nVidia GeForce GTX 460 (PCI-E 16x)
    RAM: G.Skill Extreme3 RipjawsX PC10600 (4 × 2 Go) CAS7
    Native Language: French --'
    ROG Member Alexia +10
    Jul 2011
    Location
    zzzzzzzzzzzzzzzzzz
    14
    As first, try with memory-OK button and cmos-clear jumper.
    If that doesn't work, try to remove GPU, and if this works, you've to upgrade your PSU.
    New ROGer Bigou +10
    Aug 2011
    Location
    France
    2
    Thanks, but like I saidbefore: In firsts boots, I can see (and set) the firmware. So I don't think the GraphicCard is the problem.
    Meanwhile I've successfully booted my PC.
    But...
    Does it always try to OverClock the system? Because it's "just" the OverCloking which fails, and like I’ve already said: It’s not for the OverCloking part if I’ve choose this MotherBoard, it's for provided connectivity, and I don't want to go through the BIOS on each start.
    I also think I have 1 of the 2 firmwares is corrupt. (Possible reason of restarts.)
    One more time: Thanks Alexia!
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,773
    In the traditional sense, no the motherboard does not overclock past specifications unless you set it that way. However there is Turbo Boost which is part of the i7 CPUs and is automatic.
    ASUS Maximus IV GENE-Z Intel 2600K DangerDen cooling 8GB G.Skill Trident
    ASUS GTX670 Patriot PyroSE SSD Antec Signature 650 PSU Antec Mini P180 [ ASUS G73JH ]
    Folding@Home - Join us!
+ Reply to Thread
Similar Threads
  1. Replies: 7
    Last Post: 08-06-2011, 05:41 PM
  2. G73JH Black Screen on reboot
    By RGHawk2000 in forum Older G Series Notebooks
    Last Post: 07-23-2011, 05:54 PM
  3. Crosshair V + reboot/shutdown hang ups
    By Prolab in forum Crosshair Series Motherboards
    Last Post: 06-23-2011, 04:28 AM
  4. rampage III black edition don't reboot
    By radi in forum Rampage Series Motherboards
    Last Post: 05-28-2011, 12:56 PM
Tags for this Thread
