Results 1 to 3 of 3
    ROG Guru: Orange Belt Array WeRNothiNg's Avatar
    Mar 2013
    Location
    Bismarck, AR
    31
    379
    GTX 660 Ti SLI Question
    I already own an Asus GTX 660 Ti OC. I just ordered a TOP and from what I have been readying that shouldn't matter. The only difference in the 2 cards would be the BIOS. So is it possible to flash the TOP bios onto my OC?
    **i7 3770k @ 4.5GHz~ Cooler Master V8 ~ Asus Maximus V Formula ~ G Skill Sniper Gaming Series 16GB DDR3-1600 ~ Thermaltake Black Widow 850W 80+ Bronze ~ Kingston HyperX 3K 120G SSD ~ 2x WD Caviar Black 1TB
    ~ WD 500GB ~ 2x ASUS GeForce GTX 660 Ti TOP 2GB ~ Philips 1080p 39"**
    [IMG][/IMG]
    Dec 2011
    Location
    London
    256
    25,205
    Are you 100% certain that they are the exact same PCB? And why would you want or need to have the same BIOS for both cards, I have used Palit and ASUS in SLi, as well as pretty much all brands together. The only key point has been the amount of Vram. That has to be the same.
    Mar 2013
    Location
    Bismarck, AR
    31
    379
    Yes, just one is the DC20 model and one is the DC2T. Both are 2gb cards. If having different cards will make no difference then I will just leave it alone.
    [IMG][/IMG]
