Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 28
    ROG Enthusiast Array jjxaker's Avatar
    Apr 2013
    Location
    Donets'k
    13
    30
    Exclamation Asus Z87-Deluxe problem
    MB: Asus Z87-Deluxe bios 1007
    CPU: Core i7 4770k Batch L310B488
    RAM: Corsair 2x8GB CMY16GX3M2A2400C10
    OS: Windows 8 Enterprise x64
    my system is not overclocked
    Problem:
    1) Intel Ethernet Connection I217-V does not work at speeds 1Gbps. only 100Mbit
    2) motherboard does not start at a frequency ram 2400Mhz, are using X.M.P Profile (P8Z77-V Deluxe bios 2003 works well)
    Asus, what to do?
    Dec 2011
    Location
    London
    256
    25,205
    Please show me your CPUz screen showing your memory frequency.
    Apr 2013
    Location
    Donets'k
    13
    30
    if set the frequency and timings manually, the problem remains in place!
    and still the problem, CPU does not reset the frequency constantly running at full
    Dec 2011
    Location
    London
    256
    25,205
    Please download CPUz and show me the memory screen.
    http://www.cpuid.com/softwares/cpu-z.html
    Once you select the XMP profile as your overclocking option you do need to save before you exit. So F10 and enter.
    Apr 2013
    Location
    Donets'k
    13
    30
    Quote Originally Posted by HiVizMan View Post
    So F10 and enter.
    kidding?
    Dec 2011
    Location
    London
    256
    25,205
    LOL sorry for stating the obvious but quite a number of folks forget to do that.
    OK what you are showing me is the SPD page, I want to see the memory tab. It is next to the SPD.
  7. #7
    Apr 2013
    Location
    Donets'k
    13
    30
    what else?
  8. #8
    Apr 2013
    Location
    Donets'k
    13
    30
    CPU-Z program is buggy, that you want to see there?
    what else?
  9. #9
    Dec 2011
    Location
    London
    256
    25,205
    OK thank you.
    In the bios, the main screen where you have set the XMP profile. Could you take a screen shot of that bios page. You will need a fat formatted USB stick connected to your system. F12 to take the screen.
    If you are enabling XMP profile then it seems that it is not taking. But lets confirm that with the BIOS screen.
  10. #10
    Apr 2013
    Location
    Donets'k
    13
    30
    F10 Save Post Code 55 - Memory Not Installed
