Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    ROG Guru: Yellow Belt Array Classic_GOD's Avatar
    Jun 2013
    Location
    Galactic Sector ZZ9 Plural Z Alpha
    20
    141
    3pin, 4pin, PWM, Voltage Control?
    Firs of all I'm sorry if this was answered before but I can't find the clear answer for my question.
    I'm planing to join the ROG family once the M6Impact becomes available and wanted to make sure what kind of fan speed regulation are the ROG boards capable of using for chassis fan headers. I know for that Asus uses new connector on the CPU Fan header to detect what kind of fan is connected but all the other 4-pin fan headers on the motherboard are just standard fan headers.
    The only way to control both 3pin and 4pin fans (and I know they are capable of controlling both) without any detection is to use voltage regulation or have menu item to set the type of the fan. I didn't saw any 'fan type' setting on the UEFI screenshots for ROG boards and also didn't saw option like this in UEFI of my current ASUS board (P8H77-I).
    So my question is:
    Are the chassis fan headers on new ROG boards capable of controlling fans using PWM (and if so how you set them in PWM mode) or are they always voltage controlled.
    The answer to this question will influence my choice of fans for my next build so I hope someone will be able to answer it
    Thanks.
    ROG Guru: Gold Belt Array Menthol PC Specs
    Menthol PC Specs
    MotherboardRVE / M8E / M8F/RIVEB/RV-E10/M5E/M6E
    Processor6950X/6700K/6900X/5960X/4790K/3770K/4960X/770K
    Memory (part number)Gskill Trident Z 3200 CL14/Trident Z 3600 CL 16/GskillPSC/Corsair2666/CorsairLED/
    Graphics Card #1ASUS GTX 1080 OC
    Graphics Card #2Nvidia Titam Pascal
    Graphics Card #3Nvidia Titan Pascal
    Graphics Card #4980ti/
    Sound CardOnboard
    MonitorBENQ 32" 4K X2 / DELL 30"/Acer4k/
    Storage #1Samsung 950 Pro 512GB X 2/960Pro
    Storage #2Intel 750 1.2TB/Samsung 840-850 Pro-Evo/ WD HDD
    CPU CoolerEK Predator 360/Corsair H110i/h115i/Custom Water/Chiller/SS
    CaseSeveral cases and open bench tables
    Power SupplyCorsair 1500/1200
    Keyboard AZIO / Corsair
    Mouse ASUS Strix/ASUS ROG
    Headset Sometimes
    Mouse Pad ASUS/Steel Series
    Headset/Speakers Logitech Z906
    OS Win 7 and 10 X64 Pro
    Network RouterVerizon Fios
    Accessory #1 I have other Hardware
    Menthol's Avatar
    Jan 2012
    Location
    Sothern California Sun
    181
    3,064
    I believe all fan headers are 4 pin PWN, you can set in bios several options on speed control for all headers, or speedfan with software, I believe it may only be the CPU fan header that can control a 3 pin fan properly
    Not to be taken seriously Array Raja@ASUS's Avatar
    Apr 2011
    Location
    ASUS North America
    144
    5,658
    Chassis fan headers control in DC mode only - and that will control 4 pin fans but not in PWM mode.
    ASUS Technical Marketing
    If you are located outside North America and require technical assistance or support, please contact ASUS Support for your region.
    For ASUS North America Service: http://www.service.asus.com/#!contact-us/cw8z
    Menthol PC Specs
    Sound CardOnboard
    Headset Sometimes
    Menthol's Avatar
    Jan 2012
    Location
    181
    3,064
    Thanks for clarification Raja
    Jun 2013
    Location
    20
    141
    Quote Originally Posted by Raja@ASUS View Post
    That was the answer I was looking for. Thanks!
    [EDIT]
    I know it's off-topic but if I can ask just one more related question
    Do the new ROG boards use real CPU core temps for fan control or like my P8H77-I cpu socket based temp sensor?
    ROG Member Array
    Jun 2013
    17
    Quote Originally Posted by Classic_GOD View Post
    [EDIT]
    They use a combination of the on-die sensor and a socket-based sensor to produce a value that never matches other temperature readings.
  7. #7
    Jun 2013
    Location
    20
    141
    Quote Originally Posted by Kwami View Post
    Well, that's a little disappointing. Thanks for the answer
  8. #8
    ROG Guru: Green Belt Array Henkenator68NL PC Specs
    MotherboardRampage V Extreme
    ProcessorIntel Core i7 5960X
    Memory (part number)G.Skill Ripjaws V
    Graphics Card #1R9-290X
    Graphics Card #2R9-290X Matrix Platinum
    Graphics Card #3HD 6970
    Graphics Card #4HD 5970
    MonitorAcer Predator XB720H 144herz 1ms
    Storage #1Samsung EVO 850 1TB
    Storage #2Seagate 2TB
    CPU CoolerCustom Watercooled loop
    CaseCooler Master HAFX and Storm Stryker
    Power SupplySeasonic Gold 1250W
    Keyboard Logitech G19
    Mouse RAT 7
    Headset Logitech G35
    Mouse Pad Steel series
    Headset/Speakers Logitech X 5.1 Surround
    OS Windows 10 Pro 64bit
    Henkenator68NL's Avatar
    Nov 2011
    Location
    Franeker, Netherlands
    118
    741
    Just use either Realtemp or Coretemp, they are pretty reliable.However in combination with fanspeed control, the temps from the mobo are used. And that gives sufficient cooling control.
  9. #9
    Jun 2013
    Location
    20
    141
    Quote Originally Posted by Henkenator68NL View Post
    This is what I do right now. I create a log of real core temps and temps indicated by FanExpert and based on that I determine how to set my fans.
  10. #10
    ROG Member Array
    Jun 2013
    Does that mean 3-pin fans will be controlled through voltage? I read that doing so generates heat in the controller, how will the motherboard dissipate this heat?
    I just ordered a Gene after a long indecisive struggle between the Gene and the ASRock Z87M OC Formula. Hope I made the right decision!
