Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 40
    ROG Member Array
    Jul 2013
    11
    Asus Z87-Pro AMDA00 Interface driver...
    Im getting an error on boot in the event viewer due to a lack of driver for AMDA00 Interface. I can only find .cab files online and I don't have the slightest clue how to install with .cab stuff..
    HALP?!
    Dec 2011
    Location
    London
    256
    25,205
    Please list your hard ware.
    And I would suggest that if you are running a AMD graphic card that you reinstall the driver.
    untouched Array Praz's Avatar
    Apr 2011
    Location
    Midwest, USA
    134
    3,753
    You don't state any specifics about your system. I haven't checked with Win7 but the AMDA00 Interface driver is installed as a Win8 update.
    ROG Enthusiast Array jjxaker's Avatar
    Apr 2013
    Location
    Donets'k
    13
    30
    ROG Member Array
    Jul 2013
    11
    Asus z87 pro, Intel 4670k, Samsung 840 Pro 256gb - should be the only specs you need
    I get an event viewer error and from some research I need this AMDA000 driver but I can only find it as a .cab and I have no clue how to install it..
    Don't be fooled by the "AMDA" this is not a AMD driver.
    Apr 2011
    Location
    Midwest, USA
    134
    3,753
    Quote Originally Posted by mstoochn View Post
    As I noted above the AMDA000 driver installs as part of the Win8 update so knowing what operating system you are using would be helpful as well as knowing the rest of your system components. AMDA000 driver also installs when the included motherboard driver disk is properly used. The driver itself is located in the Bin folder of the motherboard driver disk.
  7. #7
    ROG Member Array
    Jul 2013
    11
    win 7 64-bit pro - that driver is not on the disc
  8. #8
    Apr 2011
    Location
    Midwest, USA
    134
    3,753
    Then I don't know what to suggest. The driver is included on the disk everyone else receives.
  9. #9
    ROG Member Array
    Jun 2013
    6
    Quote Originally Posted by Praz View Post
    What does this Driver basically do? Thanks a lot!
  10. #10
    Apr 2011
    Location
    Midwest, USA
    134
    3,753
    Quote Originally Posted by johnvonmacz View Post
    It is an interface driver required for some parts of AI Suite.
