1 of 3 Project :: DIY Aluminum CNC (Make this tool for do Acrylic PC Case)
iD2ROG
Welcome!!!
Project No. :: 1 ,(1 of 3)
Project Name :: iD2CNC v.2.0
Project Description :: This project i will start to make Aluminum CNC and use this CNC to do my PC Acrylic Case ,why i need to make new CNC because actually i have my own CNC but already sold it ,so that that why i need to make new one.
Project design ::
Specification ::
X-Axis :: Working area 700mm
Y-Axis :: Working area 520mm
Z-Axis :: Working area 120mm
X-Axis :: Using SBR Rail ,Dual ballscrew and drive
Y-Axis :: Using SBR Rail
Z-Axis :: Using Linear guide
Spindle :: 1.5KW Water Cooled ER16 + Inverter
Safety :: All axis have limit switch
Auto Zero Tool :: Have auto zero tool
Overall dimension:: 1000x860mmx550mm
Incoming 2nd , 3rd project ::
Project No. :: 2 ,(2 of 3)
Project Name :: iD2CNCB v.1.0
Project Description :: This project i will go to make and CNC Controller enclosure actually it not much detail , it will simple and easy to do it.
Project design :: N/A
Project No. :: 3 ,(3 of 3)
Project Name :: [GT] Carbide Series
Project Concept :: It not just system , it your Style
Project Description :: This project i will go to an acrylic PC case. I design it to transparent both side and font panel to show what's your style inside or how your style inside.
Project design ::
2 version release , Right hand style and Left hand style
Specification ::
Model :: [GT] Carbide Series
Dimension :: 620mm x 540mm x 260mm (W x H x D)
Material :: Acrylic
Color :: 6 colors
Side Panel :: Transparent Side Panel
DVD 5.25″ bay :: 1
HDD 3.5″ bay :: 2
HDD 2.5″ bay :: 7 (3x for Show your SSD or HDD , 4x for standard use)
Motherboard :: ATX or mATX
Case Type :: Full Tower chassis
System Fan (Font) :: N/A
System Fan (Rear) :: 1x 120mm
System Fan (Top) :: 4x 120mm
System Fan (HDD) :: 2x 120mm
System Fan (Rear buttom) :: 2x 120mm
Features ::
- 2 version release , Right hand style and Left hand style
- Support 4x120 radiator
- Transparent side panel (show your style here)
- Support 6 colors to compatible to components inside
- Support custom name on font ( see it at "[GT] Carbide Series")
All Project by ::
Hope you like it.
PS. I'm not good in English , If i make you confuse please feel free to ask me.
28 REPLIES 28
iD2ROG
Just went to shopping for a couple week ago.
and aluminum profile and aluminum accessories just arrive today
Update my tools for build my CNC ::
and other important tool was power drill. I'll take picture it soon.
iD2ROG
Just got Water cooled spindle + Inverter + Spindle clamp. So today i do wiring and add Potentiometer to Inverter and then test them to make sure everything work fine and correct wiring.
Item arrive ::
Unpack the package
Start wiring ::
Note :: For single phase power use “R” and “T” but for Three phase power use “R” and “S” , or “S” and “T” , both will work fine.
After finish wiring then test run ::
Note :: Before start run it VFD need to parameter setting.
- PD005 = 400 (Hz)
- PD004 = 400 (hz)
- PD003 = 400 (hz)
- PD008 = 220 (220volt)
- PD072 = 400 (hz)
- PD144 = 3000
This parameter need to set up before start run spindle. Other parameter see document.
After test , It work correctly and everything good so next i need to add potentionmeter to font panel of inverter , it already have socket for putting potentionmeter into it.
Done !!! lol
Video test here ::
iD2ROG
Hope you like it.
Myk_SilentShado
Level 15
I have a question and it's been bugging me for a little while now, if you had a CNC and needed it, why did you sell it, only to have to build another?
For the old one i sold it because i need budget to build another Plasma CNC 4'x4' or 4'x8' but after sold it but lot of factor that i can't start to build Plasma CNC and i after sold it i still have some work , hobby that need to use CNC then i decide to build another one by keep it cheaper , smaller than old one.
iD2ROG
Just got ballscrew , rod rail , ballscrew support and other stuff today now i got almost everything still waiting for stepper motor driver , breakout board.
Ballscrew , Ballscrew support , rod rail and other ::
Wood base ::
After long time not update , just busy and have something to do. OK let's see some update progress and i think i will finish my machine not over 2 week.
Tap aluminum profile ::
Mark drill & tap position of Z-Axis :: This can do 2 way, 1st like picture below , 2nd print my design as scale print 😄 but i choose 1st way.
Finish build Z-Axis. More pictures see at my blog. iD2CNC.wordpress.com
I used cheap power drill that i have , it not accuracy and not precision but i can make it more precision and accuracy by process of drilling but some hole will have +- 0.2-0.5mm and how to make it still fit when mounting that was simple. OK how? if need to drill 3mm hole then just drill 3.3mm or 3.5mm hole then 0.3-0.5mm of hole will use for adjust aluminum plate when mounthing.
iD2ROG
Now electronic kit just arrive and then i will go to wiring and test run stepper motor first and then i will go to drill and tap aluminum and aluminum profile , finally start assembly the machine.
Electronic Kits ::
This components will use to start project no.2
