Page 1 of 7 1 2 3 ... LastLast
Results 1 to 10 of 67
Thread: Crosshair V Formula Easy Memory Setup Guide
    Not to be taken seriously Array Raja@ASUS's Avatar
    Apr 2011
    Location
    ASUS North America
    101
    5,360
    If using 4GB DIMMs the following setup is recommended as a starting point:
    Enter UEFI and navigate to the AI Tweaker section:
    Enter the DRAM Timing section:
    Set the highlighted DRAM Timings manually to the values shown:
    Navigate back the the AI Tweaker screen and scroll down to find the following highlighted voltages and set them manually to the values shown:
    Save and exit UEFI, and you're good to go
    ROG Enthusiast Array ahlot18's Avatar
    Aug 2011
    Location
    norway,nærbø/Philippines
    11
    49
    what if im using 8gb mem. do i need to follow your recommended setup?..I mean the voltages
    sorry im noob of this
    Apr 2011
    Location
    ASUS North America
    101
    5,360
    DRAM Voltage, use what the DIMMs need.
    Other settings use as shown. CPU/NB Voltage depends on CPU, 1.20V is average.
    ROG Member Array
    Aug 2011
    Location
    singapore
    7
    hi raja, kindly briefly explain on why dram write to write timing needed to be at 5? thanks!
    ROG Guru: Yellow Belt Array
    Aug 2011
    Location
    Finland
    11
    223
    Thanks for info, i have ordered this board to my next system, so it will help my setup. Big thanks!
    Quote Originally Posted by goncel View Post
    Im wondering that too. So precise numper, donst used memory have anything to say about that value?
    sry my bad English :/
    ROG Member Array
    Aug 2011
    Location
    UK
    13
    The above shows READ To READ to be set to 5 and the attatched thumbnail show WRITE To WRITE to be set to 5 but in either picture the other is not set could you advise please do i need both to be set to 5 or just one and if so which?
  7. #7
    ROG Guru: Yellow Belt Array EVIL_CONSERVATIVE's Avatar
    Aug 2011
    Location
    USA
    9
    195
    Quote Originally Posted by ShavedApe View Post
    From what I have been experiencing with this mechanical A## H@l3 neither works NOTHING WORKS ! I'm really considering boxing it all up tomorrow sending it back and buying an Intel system that WILL work
  8. #8
    ROG Member Array
    Aug 2011
    Location
    UK
    13
    Im currently working on 16gb 1600 but there are no guarantees that its stable as I really havent tested it I would like to confirm the above settings before I run any tests.
    *edit* I found the answer I think in this thread http://www.asusrog.com/forums/showth...e-Overclocking
    Hopefully it will work and I will have no more issues i was running 3 sticks totalling 12 gb at 1600 no problem but definately had stability issues when using 16 but now we will see running prime95 now
  9. #9
    Super Moderator Array Praz's Avatar
    Apr 2011
    Location
    Midwest, USA
    133
    3,560
    Read To Read is the important setting. Changing Write to Write will not hurt but is not usually needed.
  10. #10
    Aug 2011
    Location
    Hamilton, On
    164
    If you are successful, post specs and settings. if you are running similar ram to mine I'd like to know what settings gets you stable.
    Crosshair V Formula 990FX 0506 Bios - Phenom II X6 1100T - Gskill Sniper 1600MHz (4x4GB) - Saphire Radeon 6770 - OCZ Agility 3 60GB - WD Black 1TB - Cooler Master V6GT - Antec Dark Fleet 85 - Antec CP-850 - Windows 7 Ultimate 64
Similar Threads
  1. ASUS Crosshair V Formula BIOS Guide - Overclocking
    By Raja@ASUS in forum Crossblade (A88X) & Crosshair (990FX) Motherboards
    Last Post: 08-11-2015, 11:29 PM
  2. Replies: 13
    Last Post: 10-27-2011, 05:02 PM
  3. Crosshair 4 easy OC bios profiles.
    By chew* in forum Crossblade (A88X) & Crosshair (990FX) Motherboards
    Last Post: 09-13-2011, 08:20 AM
  4. Crosshair 4 Formula sets a new AMD maxximum memory frequency record
    Last Post: 09-21-2010, 09:48 PM
  5. PLZ.,,.POST OVERCLOKING GUIDE FOR MAXIMUS III FORMULA.,.,
    By GRIDLOCK in forum Older Maximus Motherboards
    Last Post: 09-03-2010, 06:39 PM
