Results 1 to 10 of 10
    ROG Enthusiast Array
    Jul 2013
    57
    Question Cooler Master Seidon 240M VS Corsair Cooling™ H100i ?
    So wich one do i buy ?
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    Location
    Mount Pleasant, SC, USA
    163
    7,967
    I don't think that would be a big difference between them performance-wise...
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Michelle Rudan...yes way!)
    MotherboardRampage V Edition 10
    Processori7 5960X @ stock day-to-day / 4.4GHz/4.4GHz cache Gaming / 5.1GHz/4.7GHz cache OC
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2GTX Titan X
    Graphics Card #3Not yet...
    Graphics Card #4At these prices?...Not likely :-(
    Sound CardXonar Essence STX
    MonitorDell U2711
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Monsta 480s, EK Supremacy Evo, Dual EK TitanX WaterBlocks
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    Location
    In the gutter but looking at the stars
    385
    10,981
    I'd go with the 5 year warranty on the H100i vs two on the coolermaster it's also slightly quieter like 2DB
    Jul 2013
    57
    5 year warranty no work in my country. I chosen CM 240M, cos i hate corsair..... ?....... Not like corsair link, me M6E fan expert is better, and has that diod staff on cpu cooler detect for water pump..... And i will go CM HAF XM case + many red LED 200mm CM fans, so aesthetic way better go as seidon. I just want to know if any one has 240m and any hidden problems.
    ROG Guru: Grand Master Array
    Oct 2012
    329
    13,300
    The H100i gets the win by a few degrees. But the CM 240M isn't bad either. Doesn't come with any pesky software to control the fans because you control the fans via BIOS.
    Jul 2013
    57
    1ST step before i get it :P
    I read many many reviews and i can tel you its not win. Some review's dont use at it has, cos they did not set max cpu fan speed for proper PUMP job. New Maximus 6 mb has new technology to see is it air cooler wth 4 pin, or is it pump with 3pin, so they auto set max for pump.
  7. #7
    Mar 2012
    Location
    163
    7,967
    Hm... that 4770k looks... well, naked!
    Wondering if EK's mounting screws for naked Ivy will work with the naked Haswell too?
  8. #8
    Jul 2013
    57
    They do. Just use electrical tape on cpu's vrm's.
  9. #9
    Mar 2012
    Location
    163
    7,967
    Quote Originally Posted by xfiniti64 View Post
    On those things left and upper left to the die?
  10. #10
    Jul 2013
    57
    Here we go
