Results 1 to 4 of 4
Thread: PCH Fan issue
    ROG Guru: Yellow Belt Array
    Jul 2013
    129
    PCH Fan issue
    my computer specs,
    CPU 3960 i7 extreme edition
    Motherboard asus rampage iv exreme
    dual gtx 690
    power supply evga 1500
    Ram 4x8gb = 32gb corsair cmd32gx3m4a1866c10 Dominator
    NZXT Kraken x60 280 water cooling
    my problem is my PCH fan was working before i close my desktop and upgrade bios it was working and monitored and all was goood but after i made the bios upgrade it says in Bios not avaliable and i chked it when i power on my pc i see it spin then stop then when i shut down my pc it spin as well it means working but not bios not reading it at all i dont know what to do help please.
    Dec 2011
    Location
    London
    256
    25,205
    Hello it is a know change to the bios. Go into the BIOS and navigate to the PCH fan and change the setting to disable.
    Or you can flash back to the bios version that worked best for you.
    Jul 2013
    129
    solved thanks i flashed back to the bios worked fine on it,
    Dec 2011
    Location
    London
    256
    25,205
    Outstanding mate, enjoy your system.
