+ Reply to Thread
Page 8 of 11 FirstFirst ... 6 7 8 9 10 ... LastLast
Results 71 to 80 of 102
Thread: sound issues on CHF5
  1. #71
    New ROGer tianfeng +10
    Aug 2011
    Location
    fredericton
    9
    ok update guys. I just got my new board in today and installed. I am now not having any problems with the optical out...... SO hardware not software on my end. I am still having trouble getting my first 2 ram slots to detect my ram and I can't run it in dual channel but I was just playing minecraft for like 2 hours and no sounds glitches at all. It isn't the solution we wanted but it seems to be a solution.
  2. #72
    ROG Member VirtualZ3r0 +10
    Aug 2011
    Location
    London
    17
    Quote Originally Posted by Raja@ASUS View Post
    I am in HQ and ran audio tests today and found no faults on this end at all.
    File download of all screenshots showing what we had set etc:
    http://www.mediafire.com/file/fskqnj...udio%20Bug.rar
    Checked optical rear IO header and S/PDIF header.
    Config:
    M/B: Crosshair V Formula
    BIOS:0705
    CPU and S-Spec(OPN Number): AMD ZD302046W4K43_36/30/20_2/8_A 3.01Ghz
    DRAM: PATRIOT PVS34G2000LLKN 4GB (2 x 2GB) 240-Pin DDR3 2000 (PC3 16000)
    HDD: Seagate ST3500413AS 500G HDD
    VGA: ASUS ENG310 SILENT/DI/512MD3/DP
    Audio: On-board realtek
    Audio driver Version:6.0.1.6363
    O.S Type: windows7 64 bit professional
    We can't seem to replicate on this end.
    -Raja
    Raja so you trow us in face some pictures about your test...where is that bios u was using....at the end what is the solution for this? because we are not here just to use the host webhosting and post for nothing...the problem we have is very real...we are kinda a lot who experience this...and who knows how many more but they dont know about this forum. So the problem exists. Again im asking the question...RMA or not? (is maybe only some hardware problems for some mb?..is only some users have the bad luck buyng from that hardware problems lot? )
    ASUS Crosshair V Formula 990FX
    AMD Phenom II X6 1100T Black Edition 3.3 GHz
    Corsair Vengeance 16GB (4x4GB) DDR3 1600Mhz CL9 1.5V Non-ECC Unbuffered
    XSPC Water Cooling
    Coolermaster HAF X
    2 xGigabyte GTX 560Ti OC 1GB GDDR5
    Corsair 850 W
    OCZ vertex 3
  3. #73
    ROG Member Zeus +10
    Aug 2011
    Location
    In a box
    17
    Another thread has the link for the 0705 BIOS
    http://www.2shared.com/file/rhWbb0ka...ASUS-0705.html
    I will be checking this a little later, as i am currently busy woking on a few other machines.
    Will report what i find later.
  4. #74
    ROG Enthusiast Carloshell +10
    Jul 2011
    Location
    Montreal
    69
    What did you discover ?
    I tried this bios, its stable for the OC and stuff but like I said before, the sound having delay is fixed by AI suite for me. When you turn it off, the sound stop lagging for 3000us. For the rest, I cant imagine how paintful its difficult to find the solution.
    AMD FX-8150
    Crucial 2x2gb 2133mhz
    Coolermaster Hyper 212
    Coolermaster HAF 932 Advanced
    HD Radeon Powercolor 6950 2gb // Sapphire 6950 2gb
    Enermax 1350W P-Gold
    SSD Crucial C-300 128GB
  5. #75
    Aug 2011
    Location
    London
    17
    Why should i find a solution? It is new..i buyed new..factory sealed...etc...but i guess is a hardware mistake ..thats why for so many time..it is complete silence...anyway i changed the system..i am on a g1 assassin now..having no problems..no issues..no nothing... For the rest ..good luck on finding a "solution"
    XSPC Water Cooling
    Coolermaster HAF X
    Corsair 850 W
    OCZ vertex 3
  6. #76
    Jul 2011
    Location
    Montreal
    69
    yeah thats the main question, hardware or software...
    AMD FX-8150
  7. #77
    Not to be taken seriously Raja@ASUS +20
    Apr 2011
    Location
    ASUS North America
    2,848
    Quote Originally Posted by VirtualZ3r0 View Post
    Have you even tried the 0705 BIOS?
    Nobody has come back to me since that build was posted and said their sound is glitching.
  8. #78
    Jul 2011
    Location
    Montreal
    69
    I tried the 0705 bios but my problem was only having a delay in the sound, the delay has been fixed by removing AI suite II ( the famous 3000us lag with the program you told me to download/try). I know that prismic911 (IRL friends) still have the same problem when using 0705 bios and by disabling this program. The glitching persists and stays online via optical connexion.
    Does he have to RMA his board?
    AMD FX-8150
  9. #79
    Apr 2011
    Location
    ASUS North America
    2,848
    Quote Originally Posted by Carloshell View Post
    We can't replicate it to date so I'm not sure how an RMA would help. Tell your friend to contact suport in his region and ask them if they want him to RMA.
    -Raja
  10. #80
    Jul 2011
    Location
    Montreal
    69
    I understand, since we have almost the same spec and because you guys werent able to replicate the problem, its pretty sure its hardware related.
    This is from another website :
    The main issue I have been having with this board is the BIOS. I haven't had any issues with RAM support even though my particular model number isn't listed on the official support list (8gb of Gskill 2.0gb F3-12800CL9D-4GBRL) I know some people were having issues with ram not working, but I have really bad stability issues with the latest bios update that they released 0506. Between overclocking and a few sound issues (static)
    I would finish this topic by asking you this simple question : were you also able to see if AI suite is causing some sound delay ? If yes, are they going to update the software to remove that delay? I can assure you this is software related.
    Thank you for your support Raja!
    AMD FX-8150
+ Reply to Thread
Similar Threads
  1. Crosshair V - Sleeping and sound issues
    By opmprime in forum Crosshair Series Motherboards
    Last Post: 01-06-2012, 08:49 PM
  2. Sound issues - crosshair v
    By tianfeng in forum Crosshair Series Motherboards
    Last Post: 08-17-2011, 12:12 PM
  3. Sound Blaster X-Fi Titanium sound card
    By Night Prowler in forum Crosshair Series Motherboards
    Last Post: 06-04-2011, 03:22 AM
  4. Sound is terrible!
    By kevjunba in forum Older G Series Notebooks
    Last Post: 03-05-2011, 09:38 AM
  5. Sound
    By PToN in forum Rampage Series Motherboards
    Last Post: 12-06-2010, 11:02 PM
