Results 1 to 3 of 3
    ROG Enthusiast Array
    Aug 2013
    58
    Help with SSD on Asus G750JX-TB71
    Hi everyone I am new to this conversation/ forum but i just wanted get any advice i can. I just bought this model and I believe i made a good choice. Previously i owned The Lenovo Y510p with one graphic card and a Blu-ray drive that I returned because the touch pad sucked and screen had some really bad bleeding. My question is what would you recommend for upgrades to the ram as brand and the correct one for this model so I can max out the ram and if I want to add a solid state drive 256 gig ssd. which one would work brand and model for this laptop? And to be honest with you i am no computer parts kinda guy. I'm new to gaming and I bought this laptop so I can play and do my schoolwork in college, was this a good choice? Or should I just go back to the Y510P, the one with dual graphics card and blueray optical drive that amazon is selling for $1199. I really don't know too much of the macanics of the computer. I feel for the extra 300 dollars I spent on this machine I got a better machine, meaning graphics card, better screen, better touch pad, just a more quality machine. Now if anyone could help me with this information about maxing out the ram and adding the solid state drive and maybe explain how to do it, because I really don't know how, I would be really grateful. Thanks ROG forum.
    ROG Guru: Orange Belt Array
    Jul 2013
    41
    325
    Any 2.5" SSD should work, I'd personally recommend Intel as they are a tad more reliable than others (still using the same Intel SSD for 3 years now, no issues at all). As for RAM, I'm sure others can chime in on model they've used, but if you have 8GB already you do not need more. Unless you run virtual machines all the time that do require RAM, save your money. There's no game in the world that can make use of >8GB RAM, the vast majority would be fine even with 4GB.
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    Location
    Lacombe, LA
    64
    3,230
    Quote Originally Posted by fab5yo View Post
    Install Hwinfo64 run it and you will see exactly what ram you have you'll want to match the timings and Voltages
    Just about any SSD will work, right now the best of the best is the Samsung 840 Pro.
    You can read this thread it is a sticky in the G75 G55 Forum the information applies to the G750 also.
    The Notes and guides in the linked thread are pretty clear on how go about installing A SSD. You should download ASUS Back Tracker and create a USB Restore Media first thing.
    If your not comfortable making these upgrades you should take your notebook to an authorized repair station and have them do it for you?
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    G75VW DH72 still running almost 5 years now
    Windows 8.1 Pro
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro AU
    Z97 -A
    Windows 10 Pro not upgraded to AU
