Results 1 to 2 of 2
    New ROGer Array
    Aug 2013
    2
    Plugged in not charging?
    I mean i have it plugged in and everything, but it wont like charge to "100%" it says 98% right now but it doesnt die like its not
    charging. It will say 98% plugged in not charging, but if i were to unplug it, it would go down.
    ROG Guru: Black Belt Array rewben PC Specs
    rewben PC Specs
    Laptop (Model)G55VW-3D
    MotherboardASROCK Z97 EXTREME 6
    ProcessorINTEL 4790K
    Memory (part number)G.SKILL RIPJAWZ 2400MHZ (F3-19200CL10Q-32GBZHD)
    Graphics Card #1ASUS STRIX-GTX980-DC2OC-4GD5
    Graphics Card #2ASUS STRIX-GTX980-DC2OC-4GD5
    MonitorDELL U2713HM
    Storage #1SAMSUNG SM843 480GB X2
    Storage #2WD GREEN 3TB X2
    CPU CoolerSWIFTECH H240-X
    CaseNZXT H440
    Power SupplyTHERMALTAKE TOUGHPOWER XT PLATINUM 1275W
    Keyboard CORSAIR K70 RGB
    Mouse STEELSERIES KINZU V3
    Headset STEELSERIES 9H
    Mouse Pad STEELSERIES QCK+
    Headset/Speakers LOGITECH Z506
    OS WINDOWS 8.1 PRO
    Network RouterASUS RT-AC66U
    Jun 2012
    178
    2,228
    that's normal. the charging will take place after the battery drops under 95%. it's a way to prolong the lifespan of your battery.
