Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    New ROGer Array
    Aug 2011
    Location
    Australia
    5
    G74SX USB ports not working
    After recently purchasing my G74 i was very impressed with it until i found the USB port on the right side of the laptop doesnt work. Devices connected to it are powered but not recognised, have tried USB flash drives and Mice, also tried system recovery. Has anyone else had this problem or any ideas?
    TeamROG Notebook Member Array Chastity@ASUS's Avatar
    Oct 2010
    Location
    California
    18
    1,334
    Is it a black port, or the blue one?
    Kicking Ass Since Today
    New ROGer Array
    Aug 2011
    Location
    Australia
    5
    Thanks for your response, it is the black one, which i believe is the USB 2.0 port. I should mention i have already tried a system recovery.
    New ROGer Array
    Sep 2011
    Location
    United States
    1
    I am having the same problem. I bought the ASUS G74SX-BBK7 in BesT buy. Upgraded my windows to Windows 7 Ultimate and now the USB ports are not working.
    I have tried EVERYTHING. Installed the drivers from the ASUS website. Tried manually/automatic... nothing works!
    None of my USB ports are working.
    HELP PLEASE!!!!!!!
    ROG Guru: Orange Belt Array Boosted_R's Avatar
    Aug 2011
    Location
    Canada
    12
    278
    Running Win 7 Ultimate x64
    xHCI Driver Version: 3.0.119.1
    ASUS G74SX-XC1
    INTEL 7260 AC
    Samsung 850 PRO
    TUNIQ TX-4
    BIOS 203
    335.23
    Sep 2011
    Location
    Murfreesboro, TN
    22
    368
    my instincts say hardware failure, but my brain says driver failure.
    just for the record, are you guys installing the new driver, or actually uninstalling the old one first?
  7. #7
    New ROGer Array
    Oct 2011
    Location
    Italia
    1
    Quote Originally Posted by Jaf View Post
    HELP PLEASE!!!!!!!
    Have you looked into Bios/USB Interface Security?
  8. #8
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    Location
    Massachusetts, US
    28
    2,225
    Did you install the Intel inf chipset drivers? http://pcaudio.ath.cx/stuff/infinst_auto.exe
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
  9. #9
    New ROGer Array
    Mar 2012
    1
    Unhappy usb ports not working for me either.
    Updated all drivers, and the ports are definitely not working. I have a BBK8 I got refurbished from BB as well.
    It seems to only want to look through windows update for the drivers, and when it doesn't find them, it doesn't work.
    I can't even see a flash drive.
    What gives?
  10. #10
    ROG Guru: Gold Belt Array dstrakele's Avatar
    Sep 2011
    Location
    USA
    89
    4,437
    Code 32 Error
    (from http://support.microsoft.com/kb/310123)
    Different OS in article, but this may still apply.
    Cause
    The start type for this driver is set to disabled in the registry.
    Recommended resolutions
    Reinstall the driver for this device. If this does not work, you might have to change the device start type parameterin the registry.
    Uninstall and reinstall the driver
    Uninstall the driver from Device Manager, and then scan for new hardware to install the driver again.
    You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. However, sometimes, it will open the New Hardware Wizard which may ask for the driver. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
    1. On the device Properties dialog box, click the Driver tab, and then click Uninstall. Follow the instructions. 2. Restart your computer. 3. Open Device Manager, click Action, and then click Scan for hardware changes. Follow the instructions.
    Change the start type in the Registry
    This content isdesigned foran advanced computer user.
    As a last resort, you can edit the registry directly if the driver is required, and if reinstalling or upgrading does not work. Change the start type inside the registryby using Registry Editor.
    G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
Similar Threads
  1. ASUS G74SX, windows explorer has stopped working
    By Naits in forum G Series Gaming Notebooks
    Last Post: 12-05-2012, 04:09 AM
  2. Which laptop should I choose? G74SX-XC1, or G74SX-XR1?
    By Mumps in forum G Series Gaming Notebooks
    Last Post: 08-18-2011, 04:34 PM
  3. r3e sata ports
    By glw165 in forum Other Series Motherboards
    Last Post: 08-04-2011, 11:42 PM
  4. Keep ur G74SX or return it for G74SX-3DE??? * Time sensitive*
    By Jago-Vs-Fulgore in forum G Series Gaming Notebooks
    Last Post: 08-04-2011, 08:21 PM
  5. usb ports problem
    By Lucciola in forum G Series Gaming Notebooks
    Last Post: 02-26-2011, 07:43 AM
Tags for this Thread
