Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    ROG Member Array moqel's Avatar
    Aug 2011
    Location
    Boston
    5
    Post hard drive partitions
    I am new a user of G74SX. Two questions bug me:
    1) Can someone explain to me why my hard drive is broken down into 3 parts:
    - OS (C) 440GB
    - SDATA1 (D) 232GB
    - SDATA2 (E) 232GB
    2) Normally laptop runs quietly. However, once I try to open SDATA1 (D) noise level arises and I can hear and feel the hard drive spinning. Noise and vibration are slight, but it puzzles me that it never happens when I access two other partitions, only this one.
    Thanks, from Moqel
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)G73JH, Lenovo Y500 SLI
    MotherboardASUS Maximus IV GENE-Z
    ProcessorIntel 2600K
    Memory (part number)16GB DDR3 1600
    Graphics Card #1GTX980
    MonitorBenQ BL3200PT
    Storage #1Patriot PyroSE SSD
    CPU CoolerCustom WC loop
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    177
    5,673
    What is on your D drive? If you have a lot of small files or compressed archives your computer may be trying to read them all. Possibly you might have an anti virus scanner trying to read the files as well?
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array
    Sep 2011
    Location
    San Diego
    1
    I also have a new G74SX. I have no problems with the drives, or any other part of the computer - yet. I don't understand why the 2nd drive is partitioned. I know I can change it, but I have to believe there is a reason ASUS did that. Would someone please explain?
    ROG Guru: Black Belt Array JRd1st's Avatar
    Aug 2011
    Location
    Massachusetts, US
    28
    2,225
    I have no idea why ASUS does anything, lol.
    But I DO know why I like to have big drives partitioned into smaller logical drives. 1.) Organizational - one partition could be Games, the other Documents. 2.) smaller logical drives defragment faster. 3.) I make backups with Acronis TrueImage and its easier/faster to make backups of smaller partitions that only have what you want to backup instead of EVERYTHING.
    TeamROG Notebook Member Array Chastity@ASUS's Avatar
    Oct 2010
    Location
    California
    18
    1,334
    It's a legacy setup from 1 HDD systems, so that you can have storage areas. I just merge the 2 into one
    Kicking Ass Since Today
    New ROGer Array
    Nov 2011
    Location
    Florida
    1
    Hello, folks. I hope you don't mind me replying to this thread with a similar issue rather than creating a new one. I have a G73JW-A1 and noticed a few things recently, and I was hoping to get some questions answered here.
    It appears my G73 has two HDDs. Disk Management shows these as Disk 0 (22 GB hidden, 116 GB OS C:, and 328 GB DATA D:) and Disk 1 (232 GB SDATA1 F: and 232 GB SDATA2 G:), with their respective partitions as noted.
    To date, all program that I have installed have been installed onto OS (C:), only because I let the programs use their default locations. Additionally, these programs are either installed into the Program Files or the Program Files (x86) folders.
    The OS (C:) drive was over 90% full recently untill I moved all the documents folders, etc., over to the DATA (D:) drive.
    So, here are my questions...
    1) What does "SDATA" mean? What these drives just partioned space on a separate drive?
    2) Do I have to install games and other programs onto the OS (C:) drive? What happens if I reinstall them onto other drives? Is game performance effected?
    3) What are your recommendations for my drive partitions and how I should install game programs?
    Thanks for your help!
  7. #7
    Oct 2011
    Location
    USA
    31
    2,916
    Quote Originally Posted by nickcarin View Post
    2) Do I have to install games and other programs onto the OS (C drive? What happens if I reinstall them onto other drives? Is game performance effected?
    SDATA doesn't "mean" anything. It's just the volume name. (You can change the names to something more intuitive, if your like.) "Disc" in Disc Management refers to a physical disc in your machine, while "Drive" and "Volume" refer to a partition on one of those discs. Is that what you're asking in your first question?
    When you install a program, it goes to the OS drive in one of the program folders that you mentioned. There's no reason not to let them install there, though you can put them elsewhere if you want. What's good practice, though, for programs that accumulate and use a lot of data, is to set the program to store that on a different partition.
    My general recommendation would be to have an OS partition in the 100-250Gb range....that should be more than adequate room for all the programs you're ever going to install, without being so large that it's tedious and cumbersome to back up regularly. (It's a good idea to run a system image of your OS drive regularly.)
    Beyond that, organize partitions in whatever manner seems most efficient and intuitive for you and the way you use your computer. On mine, most of the second hard drive is used for a music partition, with the rest (150Gb) taken up by a partition I use for backups....that's where I save a monthly system image of the OS drive. Because I wanted to use most of the second hard drive for music, I put all other data (My Documents, My Pictures, etc.) in a partition on Disc 0, next to the OS partition.
    But that's customized for my preferences. You can use as many partitions as you like, in whatever sizes suit you. The partition advice that really applies more broadly is the limited OS drive....I think that's a good idea for everybody.
  8. #8
    Aug 2011
    Location
    Massachusetts, US
    28
    2,225
    Actually, if he plays Steam games installing to a different drive isn't a bad idea because if he does a clean install, all he needs to do afterwards is to start Steam and let it put icons for his games om his desktop with no reinstalling of games. Any Direst X needs will be taken care of when he tries to start the game.
    ALSO, for people that like to image their disks/partitions for backup purposes, putting games on a separate volume saves a LOT of time and backup size.
    Read the User's Manual for more info.
    G74SX-A1 BIOS 203
    Intel 6230 WiFi/BT
    LG E2350 LED LCD Monitor
    Intel Series 510 120 GB SSD
    Drivers, Apps and How To's
    Latest nVidia Drivers
    JRd1st on DeviantArt.com
  9. #9
    Oct 2011
    Location
    USA
    31
    2,916
    As I said, you can install programs wherever you want. The drawback for most programs, though, if you do decide to install them elsewhere, is that they will need to be re-installed if you ever do a clean Windows install. Whether that's a concern depends on your setup and whether you're the sort of user that will ever do a clean install. (I don't think most users ever do.)
    In my experience, any OS drive up to ~200-250 is manageable in terms of easy system imaging. (Mine run in the background once a week and I never even notice.) The real problems arise when people leave an entire big drive....like 500-750Gb for the OS drive. That results in huge system images and difficulties if you ever want to transfer your installation to a smaller drive. It also just seems like sloppy organization to me.....
  10. #10
    ROG Guru: Green Belt Array fostert's Avatar
    Oct 2011
    Location
    Penticton, British Columbia, Canada
    54
    706
    My general strategy has always been to put the OS partition as the first partition on the drive, since it then ends up on the fastest part of the disk, maximizing your boot times and general OS performance. You should burn a recovery DVD (set of 5 discs) and then delete that 21.5 GB recovery partition at the front of your drive. Move the OS partition to the front, or expand it to include the 21.5 Gb of unallocated space where that recovery part was.
Similar Threads
  1. G73JH Hard Drive failure?
    By flyingpenguin in forum G Series Gaming Notebooks
    Last Post: 04-30-2013, 12:09 AM
  2. Get your G73 Hard Drive Caddy here!
    By Mason@ASUS in forum G Series Gaming Notebooks
    Last Post: 03-14-2012, 04:58 PM
  3. Asus G74 Hard Drive Install
    By captainkneecap in forum G Series Gaming Notebooks
    Last Post: 08-22-2011, 09:24 PM
  4. Asus G74 Number pad, and Hard Drive.
    Last Post: 08-20-2011, 09:29 PM
  5. 2nd hard drive install
    By ericforman in forum G Series Gaming Notebooks
    Last Post: 06-17-2011, 07:16 PM
