Results 1 to 7 of 7
    ROG Enthusiast Array
    Sep 2012
    35
    Trouble with USB 3.0 ports
    I tried using a Centon Rush 3.0 USB 32 GB flash drive. When I connect it to any of the USB 3.0 ports, I get a message saying "USB device not recognized. The last USB device you connected to this computer malfunctioned and Windows does not recognize it." In Device Manager>Universal Serial Bus controllers, the USB Mass Storage Device has a yellow triangle with an exclamation point. I can use the same flash drive on another latptop with a USB 2.0 port without any problems. I don't have any other computer with a 3.0 port. I can use a 2.0 flash drive on the 3.0 port on the G750jw without problems. So, do the USB 3.0 ports work on the G750jw? Is it a Microsoft problem? Is it a problem with Centon? Is there a fix for this?
    ROG Guru: Platinum Belt Array hmscott PC Specs
    hmscott PC Specs
    Laptop (Model)Asus G750JH-DB71 (legacy)
    MotherboardAsus G750JH Intel HM87
    ProcessorIntel i7-4700HQ XTU Cores 36x/35x/34x/34x Cache 36x -50mV undervolt
    Memory (part number)Hyundai Electronics HMT41GS6AFR8A-PB 1.35v DDR3L-1600MHz
    Graphics Card #1Nvidia 780m Asus GPU Tweak OC 932mhz/6300mhz
    Sound CardRealtek v6.0.1.7469 driver
    MonitorAUO B173HW02 V1 Custom Refresh 85hz
    Storage #1RAID0 2x M.2 SATA Crucial MX200 512GB CT500MX200SSD6
    Storage #2Crucial 512GB 2.5" MX200 CT500MX200SSD1
    Power Supply230w AC Power Adapter 19.5v
    Keyboard Logitech k400 Wireless KB/Trackpad
    Headset Sony MDR-XB500 Wired and Sennheiser RS-220 Wireless TOSLINK
    OS Windows 8.1 + 8 Linux VM's + Windows 10 Technical Preview
    Network RouterAsus RT-AC68U DLINK DIR-655
    Jun 2013
    44
    5,356
    Quote Originally Posted by z3540 View Post
    The problem is more common than you might think. The drive is trying to be mounted on an already in use drive letter.
    Put in the usb drive, cancel the error message, and look at Disk Management snapin and manually set the drive letter to a free one in the drop down for resetting.
    You can also do this by going into the Device Manager, and with the USB drive installed, find the yellow caution icon next to the USB interface that it is connected to. Right click and uninstall that device, and then Scan for Hardware changes and let the driver be reinstalled.
    It is also possible that the formatted partition(s) type(s) on the USB drive are incompatible with the destination OS. This is more likely going between dissimilar or older OS"s,
    I don't think Windows 8 has dropped support for any format types... exFAT is the one that isn't backward OS compatible, but you can get updates to support exFAT for older Windows releases.
    Administrator Array
    Oct 2012
    13
    2,441
    disable usb charger +, check bios setting, if you can restore OS.
    New ROGer Array
    Apr 2014
    2
    Hi everyone,
    I am striving with another issue regarding usb3 ports on my Asus ROG G750JW. There is absolutely no way I can make any USB3 external hard drive work on it. Well, they all connect for a few seconds during which I can see my files appear but then it always disconnects and sometimes reconnects in a totally random manner.
    And this starts to drive me mad.. I have been on many forums and it seems that many other people have to deal with the same issue, but so far I could not identify any satisfying solution. Some people advised me to use my hard drives by not plugging them completely with the usb plug (only 2/3) and then they are managed as USB2 devices. But I cannot resign myself to only use USB2 on a totally new 2014 machine! Unacceptable!!!
    Other told me to just use the Intel drivers, not the Microsoft drivers, but after a few minutes (or maybe rebooting the laptop) the problem is back just the same..
    Finally I sent an email to Asus Customer service and they told me to simply restore my laptop to its factory settings.. Unacceptable too! I do not have time to redo all the settings on my laptop. Here I must point out that I am using Windows 8.1 which might be the one responsible for all this misery... But still, it has been months now, there should have been a solution to this problem.
    Please if there is a Genius out there who had the same problem and solved it please let me know with clear instructions!!
    hmscott PC Specs
    Jun 2013
    44
    5,356
    Quote Originally Posted by GoneToAnotherPlane View Post
    Hi everyone,
    So far, all the USB 3.0 devices I have tried run at full speed, and are reliable, on all the USB 3.0 ports on the JW/JX/JH - it sounds like you have an incompatible external enclosure - the USB 3.0 chipset it uses isn't happy with the USB 3.0 chipset Asus used in the G750 - you could try another USB 3.0 enclosure - move the disk to it.
    Here are the makers of the devices/enclosures I have used that work at USB 3.0 speeds
    SIIG
    Kingwin
    Patriot
    Kingston
    What is the make/model of the device(s) that fail for you?
    ROG Guru: Orange Belt Array Prostar Computer's Avatar
    Jul 2013
    Location
    City of Industry, CA
    11
    462
    Unfortunately, USB 3.0 adoption has been slow and has created something of a bottleneck in device support/compatibility and driver conflicts. hmscott's suggestion to try another enclosure may turn up viable and would imply that compatibility is indeed the culprit.
    We customize Asus, MSI, and Clevo laptops!
  7. #7
    New ROGer Array
    Apr 2014
    2
    Thanks hmscott for your reply! I have just read it after a few months lol.. have been busy on some other matters.
    But I think my problem did indeed come from the external enclosure of my hard drives. The enclosure I use is the ICY DOCK.
    Since it seems you tried some other brands and it worked for you I might try one of these to see if it solves my problem..
    Thanks again for sharing your experience with me. I will let know on the forum if your solution worked for me or not..
