Results 1 to 1 of 1
    New ROGer Array
    Aug 2011
    Asus G73JW problems
    Hi guys,
    I have a bit of a problem with my G73. I recently did a fresh new install of Win7 due to crashes among other things. But i also experienced some problems with my wlan connection, problem was that it went up and down...
    It works kinda ok now, but the strange thing is that when i was playing som SC2, the connection went down, i've suspected it being related to USB-ports (or the motherboard). Why? Because when i disconnect 2 out of 3 devices plugged in - it works like a charm. I have a cooling pad, Razer Banshee headphones and a mouse plugged in. When i removed Headset + cooling pad it works, but not otherwise.
    So my question is if anyone else has experinced a similar problem?
    I also have an unidentified PCI device in device manager that i can't seem to figure out what it could be - i've obviously tried searching for drivers with no luck - i don't really know what it's for, so it's a bit tricky figuring out what drivers to use... It says under properties "PCI slot 4, PCI bus 5 device 0 function 0"
    Thanks in advance
    Ps. First time poster, so be nice
Similar Threads
  1. Problems with new asus g73sw
    By salaam123 in forum G Series Gaming Notebooks
    Last Post: 06-12-2011, 08:29 PM
  2. ASUS G73jw display problems.....URGENT HELP NEEDED
    By Rahul Dasari in forum G Series Gaming Notebooks
    Last Post: 03-17-2011, 11:36 PM
  3. G73JW-3DE brand new laptop with problems!
    By Heim in forum G Series Gaming Notebooks
    Last Post: 01-07-2011, 05:55 PM
  4. Asus G73-JH Display Problems
    By drew.dawson in forum G Series Gaming Notebooks
    Last Post: 12-11-2010, 05:36 AM
  5. ASUS Z8PE-D12 Motherboard problems
    By SBuffum in forum Other Series Motherboards
    Last Post: 12-07-2010, 01:12 AM
Tags for this Thread
