Hey guys, Ive been having some USB Issues and wondering if someone can help, how should i setup my USB settings in BIOS, should i use NEC or PCH and also i hear u need to connect the 4 pin molex on the Motherboard which i haven't currently but i did connect 8 PIN on top of the board next to the CPU, doesn't that do the same thing?
Also 1 more question, i currently running everything on stock and my 2600K is running at stock 3.4ghz speed and my ram at 2133, RealTemp shows my Temps as follow"
Idle: 35 35 34 34
Playing games: 41 42 39 39
My room temperature is around 78F, can u guys let me know if those temps are ok?
Also im on BIOS 1409 and wondering of i should upgrade to 1850 or 1902 and if i upgrade will it make my system more stable and better overall?
