G74SX 192 BIT GPU Overclocking Tread
Boosted_R
My scores 3Dmark11, Driver Version 280.26, did not use ThrottleStop (doesn't work for some reason):
Stock Max 62*C During Test:
NVIDIA GeForce GTX 560M video card benchmark result - Intel Core i7-2630QM Processor,ASUSTeK Compute...
OC 920/1840/1625 Max 65*C During Test:
Never Overclocked anything before, MSI afterburner made it super easy
Running lower, same or higher settings, please post. Thanks
(Used OC settings from other site, which they say run good 24/7)
(If your running 128 bit (2GB 560M) please make a new tread)
GL702VSK / GTX 1070 / M.2 960 EVO
HTPC MINI-ITX / FRACTAL CORE 500 / GIGABYTE GA-AB350N / GTX 1050 Ti Windforce OC 4G / RYZEN 5 1600 3.9GHz / M.2 960 EVO / G.SKILL Ripjaws V Series 3200MHz
OLD
ASUS G74SX-XC1 / INTEL 7260 AC / Samsung 850 PRO / TUNIQ TX-4 / BIOS 203 / 335.23
30 REPLIES 30
Chastity
MSI Afterburner has limits in its overclocking. Thus the reason I use NVIDIA Inspector.
[SIGPIC]Kicking Ass Since Today[/SIGPIC]
Sounds good, post some scores and setting 😄
Thanks
OLD
Chastity
http://3dmark.com/3dm11/1602823 952/1710
http://3dmark.com/3dmv/3327882 945/1683
Would have though you would have gotten more performance with the ram upgrade
Ran 930 setting: P2648
http://3dmark.com/3dm11/1755039
Only during 3Dmark11 at 950 setting i got a message saying Driver none responsive, recovered successfully, could it be the driver, or clocking is too high for this driver ?
What driver are you using?
Did you get Throttle Stop to run on your G74SX ? if so how?
Thanks
OLD
Thanks
I wrote a thread in the stickies on how to setup TS to work 🙂
Retired
Not applicable
Nice scores. Chas, what are your stable clocks for the G74 that'll be safe to use most of the time?
I was able to run DA2 with the 945 settings, some games needed 940.
Retired
Not applicable
Hi Guys
ASUS G74SX-91237Z 17,3"/ 3D/ i7-2670QM/ 16G/ 2x500G7/ BluRayRW/ GTX560M/3GB / Nvidia driver 285.62
I am using MSI Afterburnner 940 / 1880 / 1625, and AIDA 64 to overwatch all values on my Keyboard LCD (CPU %- Mhz - RPM(VENT) - TEMPERATURE - Voltage; MEM %-Mhz; GPU % - core - shader - memory - TEMPERATURE - Voltage;
And this is what I get: P2725 3DMARK 11
http://3dmark.com/3dm11/2102956
Running BF3 FullHD with max settings I get arround 25-30fps ingame/online CPU TEMP is arround 66C-70C; GPU is arround 58C-62C. Talking to Asus support, they told me anything under 85C for the GPU would be fine. Anything arround 90C wouldnt be good ,O))) Would wonder when the notebook shut´s down automaticly.
That'd be when the flames melt through the ribbon cables in your system. ;>{)> Seriously, I THINK, but am not sure, it would be when the CPU or GPU maximum operating temperature (110 or 100 C) is reached.
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
