Results 1 to 7 of 7
    New ROGer Array
    Aug 2011
    Location
    viña del mar
    4
    G73jh Boot issue: Bootmgr is Missing...
    It started a few months ago and randomly shows the messege "bootmgr is missing press ctrl+alt+del" shortly after ASUS logo screen appeared, I just had to reset BIOS and it worked fine. I supposed that it was a Hard disk failure so I bought a new one, but now it still doing that. Then I thought that it might be a slot problem, so I change HD position, but it still didnt work. Recently I found out that if I only run one Hard disk installed on the laptot it work normally, so I deduced that it might be a BIOS problem or something else.
    I also tried every single BIOS update available but nothing happened.
    Also tried with clear windows 7 Install.
    TIP: There is a little "beeping, squeaking... dunno " noise in the hard drive when this happens. Sometimes it also occured when i am logged into windows and the HD is re-recognized by OS.
    There is no HD malfunction because i bought a new one and when a install only one in the laptop everything works fine.
    I also discover that sometimes BIOS just won`t detect one of my hard drives.
    Thanks.
    TeamROG Notebook Member Array Chastity@ASUS's Avatar
    Oct 2010
    Location
    California
    18
    1,334
    Try updating the firmware on your HDD's. What models do you have?
    Kicking Ass Since Today
    New ROGer Array
    Aug 2011
    Location
    viña del mar
    4
    Already updated, got it from support thread on this forum.
    Samsung momentus. st9500420as
    I have changed slots again and it seem stable at the moment. I`ll keep you informed.
    New ROGer Array
    Aug 2011
    Location
    viña del mar
    4
    still random Hard drive Bios recognition... Same issue.
    Oct 2010
    Location
    California
    18
    1,334
    swap drive bays?
    New ROGer Array
    Aug 2011
    Location
    viña del mar
    4
    yep, i tried in both ways. Nothing happened.
  7. #7
    Oct 2010
    Location
    California
    18
    1,334
    You could check to see if anything like the MBR needs to be fixed.
Similar Threads
  1. Bootmgr/bios problem
    By Arxon in forum G Series Gaming Notebooks
    Last Post: 09-18-2011, 10:47 PM
  2. ASUS Crosshair v formula mobo - boot mnager missing. how do i fix?
    By kekashi in forum Other Series Motherboards
    Last Post: 08-27-2011, 02:42 AM
  3. G73JH Boot Issue
    By Canas in forum G Series Gaming Notebooks
    Last Post: 08-17-2011, 05:00 AM
  4. Cold Boot Issue
    By Uberg33k in forum G Series Gaming Notebooks
    Last Post: 03-11-2011, 01:15 PM
  5. Boot Logo+Bluescreen issue
    By RoG in forum Other Series Motherboards
    Last Post: 02-10-2011, 02:11 PM
