Edit by cl-Albert: For those interested in a summary uninstalling the ASUS ROG gaming mouse driver solved the problem (for troubleshooting verification), and installing a newer updated ROG gaming mouse driver. Thanks to Maxter and MichaelWalker in finding the solution and to shank for helping to verify it.
Another thread below related to the gaming mouse driver if anyone is interested, but some customers have reported removing the gaming mouse driver did not help them too.
http://rog.asus.com/forum/showthread.php?45718-Upgrade-to-windows-8.1-and-BSOD-KMODE_EXCEPTION_NOT_H...
MichaelWalker wrote:
Hi , Im new to ASUS and a not-so-good when it comes to computer specs.
I just bought G750X 2days ago and have experience BSOD TWICE. KMODE_EXCEPTION_NOT_HANDLED.
Both experienced it in Dota 2 and WoW . It was really pretty smooth sailing with the high end graphics and stuff but it just pop up BSOD out of nowhere!
Any help is appreciated thanks!
Maxter wrote:
SOLVED! BTW, I don't know if you noticed, but you and I were the first ones to solve this issue. There are several posts with this same issue on the forums going around... Maybe a sticky of this would be nice (admin?), since it has all the steps it took to solve the issue.
Hello Maxter. I'm really stunned that so many people here experienced the same issue as mine!
Just to clarify the ASUS users who stumped upon this thread.. do kindly read through the discussion between Maxter and I just in case you guys experienced the exact problem I faced when I first got my laptop.
Heres a Summary in case you're lazy to flip throughyansendjohan, shank, FyperX, FalconFX,littletyran apparently had it solved in the same way.
My original problem
(Trust me, I panicked like mad when I start experiencing all these problems)
I first bought the laptop and it crashed within a day. I thought it was the RAM or Graphic card problem as it BSOD only during gameplay. Apparently after sending it back to the retailer to exchange a brand new one, this time it crash when I run CCleaner.
Send it back second time to the retailer, exchanged for a new one again, it crashed again.
Decided to send to ASUS for warranty and yet the technician told me NO ISSUES. Here I am, stuck again with my repeated crashes.
Maxter chance upon my thread and decided to offer me some advice + abit of researching on my part and we finally solved it.
Heres a rough step-by-step on how I manage to solve it with Maxter's help
Firstly, ensure you
downloaded and
updated every single driver in your brand new laptop.
Secondly, check the drivers. Because chances are some drivers are either too new or incompatible with the current software, such as NVIDIA beta drivers(trust me my laptop is working fine now and the beta driver crash my game once I had to reinstall the whole driver)
Quoted from Maxter
"I activated the driver verifier from Win 7 (which is also on Win 8 - here's a link with more info on that
http://support.microsoft.com/kb/244617). I started the computer and it told me that nVidia drivers were crashing. What I did was to go into "device manager" and uninstall the Display Adapter for my GPU, then I went to "Programs and Features" and uninstalled manually everything related to nVidia. Then I went through the hard drive and deleted all nVidia files and folders left (usually in C:\). I also ran a CCleaner to remove all registry keys for nVidia. Then I rebooted. The computer installed a generic driver. I re-downloaded the latest nVidia drivers and only installed what I knew I needed (I excluded GeForce Experience - it seems to be causing BSOD in several systems from what I saw on several forums). I have been running some stability tests for 24 hours and seems stable. Since you only get this during gaming, my first assumption would be misgandling of the GPU drivers... try what I did and see what happens."
Thirdly, after all has been done and if still BSOD comes out, download whocrashed as it gives you a
DETAILED rundown of the problem compared to bluescreenviewer.
Quoted from Maxter
"Download and use "whocrashed" to get a better idea of the information in the dump file (much better than Bluescreenview). Here's the link
http://www.resplendence.com/download/whocrashedSetup.exe "
Fourth, start analyzing it.
This was my problem and I notice one of the users had the exact same problem as mine.
Maxter apparently had faced the same problem as well for the Kernel System
"Looking at that pic, seems like ntoskrnl.exe is the one at fault - I think because of Driver mishandling. Believe it or not, I was having this same crash this weekend while playing League of Legend on my desktop. Usually this cause of crash seems to be because of overclocked CPU, GPU, or memory. Since your computer is right out of the box, I'm assuming CPU, GPU and memory clocks are at default." This is in turn, linked to NVIDIA. After doing all the necessity with reference to the Second step, I run whocrashed again and it eliminated the Kernel problem.
For the athw8x.sys problem, the original driver was missing from my laptop(I've no idea why) and I went to search online to manually install the driver after flipping the ASUS driver website inside out
http://support.asus.com/download/options.aspx?SLanguage=en&type=1 and it was solved
Which left us with the most puzzling one. pxgx112.sys . <-- This is the main cause why the new laptops are CRASHING repeatedly despite running tons of updates, scan and stuff. After searching far and wide over the net I traced it back to our ROG mouse.There is an issue with our ROG mouse/gaming driver. If you had visited
http://www.asus.com/Keyboards_Mice/GX850/#support and download this driver, you will realize you now had TWO ROG ASUS mouse driver. Apparently the default one present in our laptop is
FAULTY. When you opened both and compared it side by side, even the version stated is quite different(this was an issue last year, I didn't took a screenshot of it), so I uninstalled the default ROG driver and used the one I downloaded from Asus web and my laptop has found peace ever since
😄 I hope I can be of help to the new users whos struggling and panicking/worrying like how I used to. I really thanked the forum users in this community in particular to Maxter due to his active and consistent reply to help me solve this issue. Its a really friendly and great community to be part of. My laptop has never faced an issue ever since then. Its been a good 11months for now. Cheers and enjoy your new gaming com!
