+ Reply to Thread
Results 1 to 6 of 6
Thread: G74SX problems with: TouchPad and Recovery CD
    ROG Enthusiast Bekarasha +10 Bekarasha's Avatar
    Sep 2011
    Location
    Netherlands
    40
    Question G74SX problems with: TouchPad and Recovery CD
    Hello,
    Got yest G74SX, nice killing machine thanks Asus!
    but got a small problem, i'm using external mouse and i set in touchpad properties ""disable touch pad while external USB mouse...." http://imageshack.us/f/220/89262828.jpg/
    it was working untill i restart laptop, now i whent to prperties again, did uncheck > apply and check apply and touch pad still working In Live Update nothing is available to download all is up to date.
    2nd think, is there any possibilities to make recovery DVD on usb flash drive? I'm not using CD/DVD almost 2 years During creating Recovery CD only posibility to use DVD =(
    Sep 2011
    Location
    Netherlands
    40
    1st problem is solved, instaled lates drivers TouchPad Version V15.2.16.1 and disabeld touchpad from properties, after restarting works perfectly!
    2d question is still opened i have usb 32 GB can i make it as recovery usb, DVDs is not handy
    ROG Guru: Yellow Belt irdmoose +20 irdmoose's Avatar
    May 2010
    Location
    Orangevale, CA
    151
    I don't know about a recovery flash drive, but you can download the windows 7 disc image in Chastity's sticky for the G-series laptops and apply that to a flash drive. Then you can copy all of the relevant apps from Asus that you use. It's actually a quicker way to do a clean install than using the 4 DVDs.
    Sep 2011
    Location
    Netherlands
    40
    i have partition "RECOVERY", so i guess from this partition asus will make recovery DVD's so if i copy this to usb flash & if one day windows will crash i can reinstall it?
    http://imageshack.us/photo/my-images/713/recz.jpg/
    this map have almost all files tht normal windows need to install, just need conformation ^^
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,747
    If you want to use the Recovery partition you just press F9 during boot; No DVD is required for this operation. The recovery DVD is an alternative for when you can't or don't want to use the partition.
    ASUS Maximus IV GENE-Z Intel 2600K DangerDen cooling 8GB G.Skill Trident
    ASUS GTX670 Patriot PyroSE SSD Antec Signature 650 PSU Antec Mini P180 [ ASUS G73JH ]
    Folding@Home - Join us!
    TeamROG Notebook Moderator Chastity@ASUS +10 Chastity@ASUS's Avatar
    Oct 2010
    Location
    California
    1,338
    And do not delete the Recovery partition. The DVD's you make are useless without it.
    Personally, I removed the AI Recovery app, as I find it useless, and I use Acronis to make images to external HDD's.
+ Reply to Thread
Similar Threads
  1. G74 Touchpad issues
    By kring17 in forum Older G Series Notebooks
    Last Post: 09-04-2012, 05:53 AM
  2. Troubleshooting ASUS G73 Touchpad Problems
    By V2-V3 in forum Older G Series Notebooks
    Last Post: 09-04-2012, 03:37 AM
  3. G53SW touchpad issues
    By Donald_W in forum Older G Series Notebooks
    Last Post: 09-09-2011, 08:20 AM
  4. touchpad issues
    By dwahyu in forum NON-ROG ASUS Notebooks and Tablets
    Last Post: 08-31-2011, 02:20 PM
  5. Replies: 0
    Last Post: 07-31-2011, 06:18 PM
Tags for this Thread
