Results 1 to 6 of 6
    ROG Member Array
    Sep 2013
    13
    HELP ME PLEASE!! Asus Crosshair V formula Z With dual ram issues
    Best Asus.
    I have a problem iritant've been up all night and really but really tried everything ...
    The problem is so I 4x4 GB ram total of 16 GB in dual, but cpu z says that it is single but 16 gb and windows also 16gb but 8gb available and task management says that 8 gb reserved for hardware and the bios says who have total 8 gb ram remapping enablement put all standard windows 8.1 reinstalled ... and because I have this motherboard, I thought I mail you a while if you know something ....
    asus crosshair v formula z
    my pc specs are:
    Windows 8.1 64 NL
    Vengeance ® Low Profile - 16GB Dual Channel DDR3
    FX6300 amd processor at 3.5
    Do you know what this is and what I can do because the motherboard asus and actually everything goes through the motherboard, it
    so it seems to me that it is the motherboard.
    let me know something please!!
    have been more than 24 hours awake!!
    M.v.g Wouter
    p.s. Sorry for my bad english.!!
    have u qestions? or u know how or what ?? pm me thanx!!
    iron man Array kkn's Avatar
    Aug 2011
    Location
    norway
    218
    5,885
    what sort of windows version of 8.1 do you have??
    CPU: i5-3570K | MB: M5F | Mem: 16GB dominator platinum | GPU: EVGA 980TI | SSD: a few | PSU: Corsair 1200i | Monitor's: 2x 27" ACER predator 1440P 144HZ G-SYNC
    ROG 師傅 Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Michelle Rudan...yes way!)
    MotherboardRampage V Edition 10
    Processori7 5960X @ stock day-to-day / 4.4GHz/4.4GHz cache Gaming / 5.1GHz/4.7GHz cache OC
    Memory (part number)F4-3200C14Q-32GVK
    Graphics Card #1GTX Titan X
    Graphics Card #2GTX Titan X
    Graphics Card #3Not yet...
    Graphics Card #4At these prices?...Not likely :-(
    Sound CardXonar Essence STX
    MonitorDell U2711
    Storage #1Samsung 950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB
    CPU CoolerCustom Loop: Dual D5s, Dual Monsta 480s, EK Supremacy Evo, Dual EK TitanX WaterBlocks
    CaseNope!...Phobya Bench...let it all hang out man!
    Power SupplySeasonic SS-1200XP3
    Keyboard Logitech G810 or Fender Rhodes Electric Piano (MKI 73)
    Mouse G502 or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    Location
    In the gutter but looking at the stars
    385
    10,982
    Do you have one kit or two dual channel kits?
    ROG Guru: Diamond Belt Array Zka17's Avatar
    Mar 2012
    Location
    Mount Pleasant, SC, USA
    163
    7,967
    Before you would go into OS, try every module in every DIMM slot with memtest86+ - if that works, then both your mobo and RAM is OK...
    Then try two modules in red slots, then all four modules - at least 4 cycles... first a BIOS defaults, then at your desired OC settings... there is no warranty for OC'ing usually, but the specs on the modules should be achievable...
    AntiMatter Guru ROG Array chrsplmr's Avatar
    Jul 2011
    295
    6,111
    Also from Raja long back .. and vengeance has been a problem for a while ..
    Enter the bios:
    Go to Dram settings..
    scroll down to [read to read] change it to 5 (I believe default is 3)
    then scroll to the bottom and change the default typerate from T1 to T2 ..
    This may get you up and running until you can 'tweak' out the particular
    issues between your cpu and memory .. no 2 play together the same.
    Also, if you have not before .. in the CrossHair section of the forum under the stickies you will
    find an extensive 'memory database' started by @Kipper, added to by many, especially @Praz
    Best of Luck.c.
    ROG Member Array
    Sep 2013
    13
    hello thnx bro,s for the comments first answer i have windows 8.1 64x nl by system settings says windows 8 so no pro i think
    arne i have now ne dual channel kut 16 gb 2x8 of corsair dominator platinum 1600
    and chrsplmr i try that now i come later back
    thnx for the advise
