+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: ROG Thunderbolt Sound Card
    New ROGer Jay Cee +10
    Sep 2011
    Location
    VA
    2
    So I am probable just missing something very obvious but I guess I'm going to have to ask the question anyway. On the back of the thunderbolt card there is only one input and 1 output..... so does this mean that the card only supports stereo? I need a little help on this one.
    I have a Tritton AX 51 Pro headset and it supports 5.1 true surround sound. So how do I get this to work.
    Thanks for the help.
    ROG Guru: Orange Belt Six Foot Ginger +10
    May 2011
    Location
    Folsom CA FTW
    493
    that's right the card is only 2.1
    Intel Core i7 Extreme 980X @4.2
    Rampage III Formula
    Corsair DDR3 2000 Dominator at 1600 7-7-7-20 at 1.5 volt
    Intel 320 Series 300 GB SSD
    Corsair Graphite 600T
    Corsair H70
    Corsair AX1200 watt
    2x Asus 580 CU2 at 840/4100
    TeamROG ADMIN Brian@ASUS +10 Brian@ASUS's Avatar
    Mar 2010
    Location
    USA, Fremont
    1,927
    unfortunately the thunderbolt was designed specifically for 2 channel headphones and does not support 5.1 channel. if you want to use 5 channel you can use the on board audio.
    ASUS is pronounced "Ay-SOOS"
    ROG should be pronounced "R - O - G"
    Become a fan of our facebook: www.facebook.com/ASUS
    ROG Guru: Black Belt Area 66 +20 Area 66's Avatar
    Jun 2011
    Location
    North of Montreal
    2,283
    Can you use both at same time ? ( it's a long time I want ask this one )
    Mar 2010
    Location
    USA, Fremont
    1,927
    i think windows allows you to enable only 1 sound card at a time.
    ROG Guru: Orange Belt Cyrekk +10 Cyrekk's Avatar
    Jul 2011
    Location
    Vancouver, BC, Canada
    401
    Quote Originally Posted by Brian@ASUS View Post
    This is correct for Windows 7, you used to be able to enable multiple sound devices in some older versions but this support has since been dropped. (Unfortunately)
    New member? Introduce yourself here, learn a little of what we are about here, and refer to some simple rules here.
    Though typically not required or enforced, here is a list of guidelines on proper forum etiquette.
    [Work in progress]
    The Crosshair GENE will come! - Show your support HERE!
    SYSTEM SPECS
  7. #7
    New ROGer Tidus +10
    Sep 2011
    Location
    Moscow
    1
    I have connected ThunderBolt S/PDIF OUT to Home Theatre System (DAV-SR4W). When I watch films by The KM player I see that sound Dolby Digital or DTS, but in game always 2.1 stereo. How can I get 5.1 sound in game on S/PDIF? And how activate DS3D GX (DirectSound3D Game Extensions) in ThunderBolt control panel? Thank you.
    Motherboard: ASUS Rampage III Black Edition
    CPU: Intel Core i7-960 3.2GHz
    GPU: ASUS GeForce GTX 570 1,28Gb
    Memory: Corsair Dominator GT 6Gb 1866MHz
    HDD: 2x WD Caviar Black SATA-III 1Tb
    Sound: ASUS Xonar HDAV1.3 Deluxe
    PSU: Enermax REVOLUTION 85+ 1020W
    Case: Corsair Obsidian 800D
    CPU Cooling: Corsair H100
    OS: Windows 7 64Bit
  8. #8
    ROG Enthusiast mkvtec +10 mkvtec's Avatar
    May 2011
    Location
    UK
    26
    I think it only depends on the game. Some Games have audio settings so you can change type of sound and layout of speakers. But most of them depend on setting from your audio manager in windows.
    i7950~4ghz. With NH-D14 Noctua
    6GB Corsair Dominator GT2000
    2x MSI GF580GTX Lightning
    Corsair AX1200 PSU
    Coolermaster HAF-X
  9. #9
    Sep 2011
    Location
    VA
    2
    WOW. Seems like a FAIL to make a discrete sound card, advertise that it will give the "extreme gamer" an advantage because you will be able to hear "better" only to support 2.1. Thanks for the help on this one guys. I guess I will just use the on board audio (which IMO is great) and go from there.
    The NIMROD Build
    Intel i7 960 4.0Ghz, Asus Rampage III Extreme MOBO, Water Cooled Asus GTX 580, Asus 550 Ti PhysX Card
    OCZ Vertex 3 Series – MAX IOPS Edition, Corsair Dominator GT's 8-8-8-24 2000 Mhz
    I7 990X for benching on OCZ Cryo Z Phase and Koolance DIY Liquid Nitrogen Evaporator Chamber
  10. #10
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,835
    Quote Originally Posted by Jay Cee View Post
    The AX 51 is the exception rather than the rule. For most "extreme" gamers they will have a 2 driver headset and the best possible setup for such a headset is something like this. For people with separate discrete inputs they would not benefit from something like the thunderbolt anyway because the external device is doing all of the mixing and any crossover on its own.
    ASUS Maximus IV GENE-Z Intel 2600K DangerDen cooling 8GB G.Skill Trident
    ASUS GTX670 Patriot PyroSE SSD Antec Signature 650 PSU Antec Mini P180 [ ASUS G73JH ]
    Folding@Home - Join us!
+ Reply to Thread
Similar Threads
  1. ASUS G60JX sound card
    By Zanetti in forum Older G Series Notebooks
    Last Post: 08-27-2011, 08:20 PM
  2. Thunderbolt add-on card question
    By jewie27 in forum Crosshair Series Motherboards
    Last Post: 08-07-2011, 06:52 AM
  3. Thunderbolt
    By CrazyShooter in forum Crosshair Series Motherboards
    Last Post: 08-05-2011, 09:28 PM
  4. Thunderbolt Add in + Onboard Sound
    By celticguy75 in forum Rampage Series Motherboards
    Last Post: 07-24-2011, 10:28 AM
  5. Sound Blaster X-Fi Titanium sound card
    By Night Prowler in forum Crosshair Series Motherboards
    Last Post: 06-04-2011, 03:22 AM
