Mini ITX Water cooled
Smaug
Here's my latest build. I call it the Minimus for obvious reasons, It packs a huge punch in very small case. Specs below, tell me what you think.
Silverstone SG06BB-LITE
ASUS Maximus VI Impact
Intel i7 4770k
2x 4GB (8GB) Corsair Dominator GT 1866MHz
ASUS GTX 760 (unfortunately the 760 water blocks will not fit this card... see notes at the bottom)
Samsung 840 Pro 256GB SSD
Athena Power Apollo 600W
Water Cooling:
Alphacool DT-LT Pump/top/rez combo
Alphacool 120mm Radiator (30mm thick)
Bitspower AIZ87M6IITX Nickel/Red water block
Monsoon Fittings (the orange looking adapters are bitspower #disapointed)
32981
32982
32983
32984
32985
*I had to RMA a waterblock for the video card because ASUS moved come components on this video card. If you want to water cool your video card look to another card as this one does not have a water block available for it!
Maximus VI Impact, 4770k @4.6GHz, 8Gb Corsair Dom GT 1866, ASUS GTX 760 DCII, Samsung 840 Evo Pro 256Gb SSD, Water Cooled with Bitspower & Alphacool
11 REPLIES 11
Chino
Level 15
Thanks for the reply Chino, I've done some wire cleanup. Also, I didn't like the Phobia Black (purple) coolant so I replaced it with clear distilled water. Here's some more pics on the build...
Here are the components..
33333
I am still building this wood case (I call Pagoda). Unfortunately the water block I purchased for the video card will not fit ASUS' GTX 760 so I'm stuck with the air cooling which won't fit this case. 😞
33334
33335
33336
Water cooling components... this was a 92mm rad. It's since been replaced with a 120.
33337
33338
Top and read shot of the system -power supply, SSD and video card
33339
33340
Side view with Power supply and cable management cleaned up.
33341
Completed with nice shot from behind.
33342
Thanks for viewing.
abvolt
Level 11
very cool I really like it good job dude..
Current: MSI Xpower Gaming Titanium | 7700K | G Skill Ripjaws V 3000 16Gb | 960 EVO 500Gb | Intel 730 480Gb | Seasonic 1000 Platinum |
NZXT X62 | Acer XB270HU | EVGA 1080 ti FTW3
Secondary: R4BE | 4930K | G.SKILL 2400 16GB | Corsair AX 1500i
Intel 730 240GB + 480GB | EVGA GTX780 ti sli kpe | Custom H20
Cartoon
Very nice build! I can't seem to find the Airflow installed in the motherboard. Does it fit?
Thanks for the comment. The fans for the memory? No, they definitely wouldn't fit. They would if I reroute the tubing but there is barely enough room to remove the memory. If they ever release a water block for this video card I'll have to get it and maybe I'll throw them in then.
canguder
fast , small , good looking great work
CPU: INTEL I7 4770K @ 4.5 GHZ
AIR COOLER : ZALMAN CNPS14X
MOTHERBOARD : ASUS Z87 DELUXE-DUAL
RAM : GSKILL TRIDENT 2X8GB+2X4GB 2400 MHZ (24GB TOTAL)
GRAPHICS : ZOTAC NVIDIA GEOFORCE GTX 780
SSD DRIVES : 2X SAMSUNG 840EVO 120GB
HDD DRIVES : 4X3TB HDD , 4X1TB HDD , 2X2TB HDD - 12TB FIRMWARE RAID+8TB FIRM+SOFT RAID
CASE : AEROSTRIKE X ST
POWER SUPPLY : SEASONIC G-750 80PLUS
FANS : 9X120MM COOLER MASTER LED , 8X140MM XIGMATEK , 1X200MM AEROCOOL , 1X200MM COOLER MASTER , 1X120MM AEROCOOL
Myk_SilentShado
Level 15
Nice looking build. Note on the VGA not having a water block, usually most block makers start off with the reference blocks and then sometimes, they make blocks for the DCii's TOP's etc....depends on the popularity of each type from the VGA Mfrs.
Thanks for all the nice comments. I hope they do come out with a water block for this card. If they do I'll be able to move all of this into my pagoda... the wood case teased in one of the pictures here... I may have to create a new thread for that one.
Smaug
I did some more searching and I found a water block for my video card! Just bought it I'll post the results when it gets here.
For anyone with the ASUS GTX 760 DCII and want a water block here's the one I've found: http://www.performance-pcs.com/catalog/index.php?main_page=product_info&products_id=35204:bf622c87d7...
