+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
Thread: Razer BlackWindow keyboard with mouse-click simulation
    TeamROG Folding@Home ottoyu34 +10 ottoyu34's Avatar
    Apr 2010
    Location
    Canada
    753
    Razer is readying a new high-end mechanical keyboard for gaming. Named the Razer BlackWidow Ultimate, the keyboard is one of the first to feature illumination. Being a mechanical keyboard, each key has its own mechanical switch compared to conventional keyboards that have a common plastic printed circuit membrane with rubber dome switches. Mechanical keys give better tactile feedback for better control. Apart from the standard 102-key US layout, Razer added several special and macro-bound keys that can be managed from the included software. The keys as well as the company badge is illuminated blue. Razer's BlackWidow Ultimate is expected to cost $129 in the US, when it launches later this week.
    Update (18/8): Razer also has a standard variant of the BlackWidow (minus the "Ultimate" marker, which lacks key illumination. This one is expected to be priced at $79.99.
    Source: http://www.techpowerup.com/128992/Ra..._Keyboard.html
    |800D|Core i7 980X - 4Ghz - H2O|Dominator 1600 6GB|Rampage III Extreme - H2O|Nvidia GPUs|OCZ Vertex 120GB|Antec TPQ 1200W|
    ROG Enthusiast Hpnotiq +10 Hpnotiq's Avatar
    Aug 2010
    Location
    V2-V3's Slave Cell
    33
    !!! MECHANICAL KEYBOARD !!! I'm pre-ordering this right now! I just can't decide if I want the Ultimate or not, though the $80 variation probably wont have clear lettered keys, probably painted white/silver.
    Quote Originally Posted by Kaboom
    The larger slot? Tried and didn't get any reaction.
    http://www.nexgenconsulting.net/
    ROG Guru: White Belt craigbru +10 craigbru's Avatar
    Jul 2010
    Location
    Nebraska
    88
    I'm typically not a Razor fan, but this has me intrigued. It looks simple and clean, although I'm not a fan of the blue illumination. If I make the purchase, some modding may be in order.
    Project: OSIDIAS - CNC by Romaxx
    Losias Technologies & SFF Modding Forums
    Quote Originally Posted by ShadowHunter
    dude, stop trying to create Skynet. at this point, the scale goes - metric tons of awesome < epic < overkill < you
    TeamROG Moderator xeromist +30 xeromist's Avatar
    Jul 2010
    Location
    Sacramento, CA
    4,755
    You mean you don't like blue or illumination in general? No need to mod it if you buy the cheaper one without illumination.
    ROG Guru: Yellow Belt Victus +10
    Aug 2010
    Location
    Florida, USA
    153
    I think it's because the blue wont match his rig. That would be my peeve. I got lucky with mine, I wanted red lighting though the LEDs on the ATCS840 are a stunning bright blue. So it matches my Saitek Eclipse keyboard and Razer Lechesis which is both blue lit. Since my case isn't windowed, I can probably get away with blue lighting inside. Then get this to replace my Eclipse since that thing has crumbs all over inside it. Not sure I want to blow 130 just yet though.
    CPU: Intel i7 930 @ 3.8GHz
    Mobo: ASUS Rampage III Extreme
    GPU: SLI ASUS GTX480
    Memory: 12GB Corsair Dominator GT 1600
    SSD: OCZ 120GB Vertex 2
    HDD: WD 1TB CB SATA 6GB/s
    PSU: Silverstone 1000w
    Case: Cooler Master ATCS 840
    TeamROG GirlGamer Kaboom +10 Kaboom's Avatar
    May 2010
    Location
    Sacramento/Seattle
    122
    Oh geez, better bring back the hot pink stilettos and big hair then.
  7. #7
    Aug 2010
    Location
    Florida, USA
    153
    Matching lipstick?
    Another downer I have yet to mention since I figured it may grow on me. Is the typeface on the buttons. Don't know exactly what it is, I just simply don't like it.
  8. #8
    New ROGer klsi +10
    Jun 2010
    7
    is that good for sc2?
  9. #9
    Apr 2010
    Location
    Canada
    753
    This is no doubt on the wish list. The standard one will have sliver coloured keys instead.
    check out the mini-site of it.
  10. #10
    Jul 2010
    Location
    Nebraska
    88
    Quote Originally Posted by xeromist View Post
    I like the illumination, just not in blue. Most of my keyboards have been from Logitech, and I'm a huge fan of the v.2 G15.
    Quote Originally Posted by Victus View Post
    Exactly, the blue won't match. I'd love to have another orange backlit option, or even white LED. Sure, I know I can get white illumination in other boards, but I want something pretty high in quality and feel.
+ Reply to Thread
Similar Threads
  1. G73 Keyboard issues
    By Mif in forum Older G Series Notebooks
    Last Post: 12-07-2010, 10:24 AM
  2. Razer Unveils StarCraft II Themed Gaming Peripherals
    By ottoyu34 in forum General Hardware, Overclocking & Tweaking
    Last Post: 06-18-2010, 09:36 PM
