does your system plays the game better when crossfire is disabled?
also, you may want to disable ulps via registry. it is a good idea to disable that when you are using more than 1 GPUs, and it wont hurt your system (just uses more power).
go to RUN, and typed " regedit " (without " ofcourse)
and FIND " EnableUlps " (without " too)
and change all of those entries from 0 to 1
close it, and restart
also, under control panel, power option
select advanced power setting
PCIE, and select NONE for power saving
need to restart too
give it a try, it wont hurt your system, and see if that helps
just a comment:
6 HDD uses alot of power, it would be better if you use just 1 large HDD instead
altho this thing isn't causing the low fps problem
oops forgot:
I know this is a very boring question... but which display driver you are using at the moment?
Aristo, an Enthusiast GamerPlay on Steam? Add me http://steamcommunity.com/id/heichalot/"Everytime my setting passes HyperPi or Prime95, I get a boner"
-meLG 60UN5400 Asus Rampage V Extreme Intel i7-5930k Haswell-E Kingston HyperX DDR4 2800 16Gb (4x4) Asus RoG Ares II no. 789 & 179 Corsair AX1200 NZXT Kraken x60 Bose Companion 5 Sennheiser HD600 Logitech G13 Corsair K95 Logitech G500 Logitech HD Pro C920 Coolermaster Haf X
