ROG connect
Hans
My ROG connection isn't working install it on the desktop with the rampage 3 usb in switch on usb other computer tried also laptop. NO CONNECTION AVAILABLE.
Retired
Not applicable
Did you install rc tweakit on the laptop? Or 2nd computer?
Retired
Not applicable
Hi
I have the same problem now.
It does not connect!
I've had it working for a few days ago, but cant get it to work now!
Is it safe to try to connect ROG to your computer (the one that have the asus rampage 3 motherboard) to test if it's my laptop that have a problem.
I will be creating a loop... but for testing only...
